Dropped! My Weekend Project - Page 3 - Fuelly Forums
Old 10-24-2006, 10:48 AM   #21
Originally Posted by krousdb
I have reduced my frontal area by 28 square inches! Thats gotta be worth a few MPG's!
You reduced by 28 square inches? How do you figure this? Just by lowering the car? No way, Jose'! Seems to me you didn't change the frontal area...just lowered the total a bit! Did I miss something? Air still goes under the car...at about the same mass flow rate (velocity / compaction).
An air dam would force a portion of this air up & over...not letting the mass get "tangled up" under the cluttered undercarriage. Of course, a smooth bellypan would be best ; that's been done, too! With marginal benefits.... -TH
Old 10-24-2006, 11:00 AM   #22
Frontal area was changed: a little less of the front tire treads was exposed after lowering.
Old 10-25-2006, 03:50 AM   #23
Originally Posted by JanGeo
Get a laser level and slap it against the side walls of each tire and see where the laser beam converges - I think about 300-500 feet is about as much toe in as you would want - 1000 feet intersection is about 1 degree - if the beam diverges from each side you have toe out - which is really bad as I found out!
Some front wheel drive cars specify TOE-OUT.
Number Section of iOs keyboard boostventilator Fuelly Web Support and Community News 5 09-23-2012 10:23 AM
higher Octane = Better MPG JBW General Fuel Topics 9 04-04-2012 12:54 AM
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 01:14 AM
Fixed Gear DirtyOldTown People Powered 7 07-04-2006 07:05 AM
Make the page lengths 30 posts again, please SVOboy Fuelly Web Support and Community News 4 05-18-2006 01:43 PM
