diy mpg gauge - Fuelly Forums
Old 08-12-2007, 01:37 PM   #1
Originally Posted by skewbe View Post
I believe my injector has a switched ground, so I'm on the other side of that, counting on the voltage drop across the resistor to give me a signal.
Wouldn't you need to pull infront of and behind the resitor in order to read the drop across it? In fact wouldn't doing it that way cut your max voltage off at whatever can pass through whatever weight the resistor is?
Right now you're pulling from infront of and behind the diode array (which I still don't understand as I don't understand diodes). I will give it a try though.
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 03:48 AM
