07-21-2007, 12:12 PM
Pretty cool ... but I don't quite understand your diode clamp interface you used.
Could you explain how you make it work?
You connected directly to the injector via a 10K resistor?
And then you grounded the signal via a diode bridge? Is that to avoid having signals above 0.6V? Don't understand...
And what's VSS for?
I though you'd use a coil to detect the pulses so the laptop would be totally independant from the car's electrical circuit...
All you have to do now to compute duty cycle is count the number of samples above a threshold vs all the samples.
You may need to adjust with a constant, or adjusting the threshold since the ramp up slope is not vertical, but seems constant.
