DIY LEDs, the easy way... - Page 2 - Fuelly Forums
Old 09-10-2007, 04:11 PM   #11
|V3|2D
thisisntjared's Avatar
yes 18ft is quite an exaggeration, but i tend to notice that i respond more quickly to leds, where as the conventional bulb is sometimes easier to ignore. this is particularly true with traffic lights if i am changing cds, so i think it would be just as true with people tailgating while on the cellphone.... just a thought anyway, i just order 4 tail light/brake light led bulbs
Old 09-17-2007, 08:58 PM   #12
mjo
Originally Posted by Diemaster View Post
yes leds are safer. at 60mph an led brake (not break ) will light up 18ft sooner. thats enough to prevent a rear end colision.
If you are stopping that fast you'll have much more serious problems. I.e. like flipping over.
mjo is offline   Reply With Quote
Old 09-17-2007, 09:00 PM   #13
How the hell could you flip a car end over end like that just by slamming the brakes?
Old 09-18-2007, 06:34 PM   #14
|V3|2D
if you are in an suv and you slam on the brakes while turning, it could definitely flip.
all you need to do is get the rear to lose traction so the vehicle gets sideways, then when it gains traction again... well there it goes. but yea, i really doubt that happens often.
Old 01-03-2008, 10:32 AM   #15
101mpg's Avatar
Search function works
This is GREAT! I will definitely be using these LEDs in my quest for better FE, lowering my alternator requirements, etc. Thanks ever so much!
And I'll be doing it on a CRX which is the exact car Draco did this on. I'll be using a meter to measure currrent draw on both the LEDs and the bulbs that they replace, letting me know how much I can step down the alternator.
Anyone know of good LED replacements for headlights? Surely SOMEONE out there has done a good LED headlight replacement?
Old 01-04-2008, 06:00 PM   #16
GasSavers_Diemaster's Avatar
wow i'm back from the dead
no one is more enthustiatic about LED's in there cars than i and i have searched high and low for LED headlights. long story short, there arnt any. simply put, theve just come out with some 20,30 watt ones but there not bright enough to meat D.O.T. standards to be a safe headlight bulb. the clocest thing is to get some HID's compared to halogens that draw 10-15A total, HID's once warmed up (after they get full brightness) only draw 6-8A, total.
they have made some foglight/ driving lights LED's but there not bright neough to be used at night for headlights.
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Currency conversion thecivvie Fuelly Web Support and Community News 1 01-26-2012 11:09 PM
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 11:17 PM
Engine Types danb86 Fuelly Web Support and Community News 3 09-11-2009 01:54 PM
Front Wheel Skirt Experiment hawkgt647 Aerodynamics 43 10-25-2006 08:34 PM
Compression Tester krousdb General Maintenance and Repair 7 07-12-2006 02:59 PM
