Originally Posted by QDM
My method is to use a 9' long piece of steel U channel and 8 1/4" bolts. On the flat garage floor I set the U channel along side the car, on top of a cinder block and a 2X4 to get the height the same as the axles. I drill holes in the U channel and put the bolts in heads out with nuts on both sides so I can adjust them in and out. The bolts touch the edges of the wheel just inside the outer lip. On my Swift the rear track is 1/2" narrower than the front so the bolts are adjusted in 1/4" more than the front. Then the bolts are adjusted for a slight toe in at the rear and 0 toe in on the front. At that point I just reach under the front and rear of the car and adjust the toe in until the wheel rims touch the bolt heads. Works great.
Hugemoth
Seems like the method should work well, but how are you sure the "U" channel is parallel to the centerline of the car? I can see how this would work to get it close, but I'm not sure how this will work if your track of your front or rear wheel is off a little bit due to worn bushings. I could see it working if you had the 9 foot piece of metal on both sides, and measured to make sure you made a 90 degree rectangle where the "box" would be formed.
Thanks for the ideas.
