DIY floats - Page 6 - Fuelly Forums
Old 06-25-2009, 03:49 PM   #51
Yes, you're right, that was the one.
co de pen den cy
Function: noun
Date: 1979
Old 07-24-2009, 03:09 PM   #52
Finally got some acceptable tubing. Couldn't get the size I wanted, so I used my lathe to rebore some plastic tubing for loose fitting bearings. Its only purpose is to protect the polyurethaned foam from possible wear. Here's a picture of what I have in mind. The pink is the polyurethaned foam, which has the plastic bearing with a small piece of aluminum tubing at the top which would be connected to a flexible wire (not shown). The float rides on a long aluminum tube that is connected to common and pins placed in it would be touched by the float borne contact. The central tube would also provide a place to run the wires, keeping them out of the way.
co de pen den cy
Function: noun
Date: 1979
Old 07-24-2009, 03:22 PM   #53
Added a top view, as well as a picture of the float making electrical contact. Still no wires, though (the program I'm using kind of sucks for that sort of thing).
co de pen den cy
Function: noun
Date: 1979
Old 08-23-2009, 07:53 PM   #54
Ran across this today.
http://www.sparkfun.com/commerce/pro...oducts_id=9072
It'd only read the, say, last 7" of the tank but they'd work great if all you cared about was the level nearing empty or you didn't mind spending the money for a couple of them...
An aluminum pipe on a float that raises or lowers into another aluminum pipe just a little bit bigger would work if you could read the capacitance too and would be cheaper.
- Kyle
Old 08-24-2009, 04:09 AM   #55
Neat. I considered just using capacitance (oil vs air dielectric would change it), but thought the switches were simpler. Actually been getting some decent weather so this project's on the back burner.
co de pen den cy
Function: noun
Date: 1979
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 11:17 PM
Engine Types danb86 Fuelly Web Support and Community News 3 09-11-2009 01:54 PM
prices vs posts here... slurp812 General Fuel Topics 41 12-19-2008 09:23 PM
Sterling Heat pump Steve6f8eh Experiments, Modifications and DIY 4 07-29-2008 01:42 PM
Compression Tester krousdb General Maintenance and Repair 7 07-12-2006 02:59 PM
