DIY floats - Page 5 - Fuelly Forums
Old 06-11-2009, 07:29 PM   #41
Wow, that sucks. My handwriting is terrible even without any electrocution! My uncle has a small cannon he can't ever fire because he lives in a suburb in CT. I'm trying to convince him to "loan" it to me.
co de pen den cy
Function: noun
Date: 1979
Old 06-11-2009, 07:40 PM   #42
It was a temporary loss of use(about 3-4 months) but still not the same.
Those phototransistors will work with the floating dowel idea. Just put a flag on it to block the light to it. Do you know what kind of light they need? Looks like UV.
- Kyle
Old 06-12-2009, 04:58 AM   #43
They say they are infrared. I believe I have some IR LEDs kicking around.
I like your home brew idea, though. Started off with lever switches in mind, but to keep it smaller, I think attaching a metal plate to the top of each float will work better. Still working on the details.
co de pen den cy
Function: noun
Date: 1979
Old 06-12-2009, 05:25 PM   #44
Found a decent float material at the dollar store: flower arrangement foam. Unlike a lot of it, this has a very small cell structure, so it'll take a coating of polyurethane nicely (to protect it from the oil). Cheap as chips.
co de pen den cy
Function: noun
Date: 1979
Old 06-12-2009, 07:14 PM   #45
Nice! I'd take one of your prototype floats and sink it under oil for a week or two to see how it does.
Dumb question, but you are using water-based urethane right?
- Kyle
Old 06-12-2009, 07:20 PM   #46
Yes, water based. Not a dumb question at all.
I'm thinking of using a central tube that the floats ride on. They'd have a plastic bearing so no wear would occur. All the wires would run inside the tube to keep them out of the way and come out through holes where needed. Each float would have a sheet metal disc (flashing, really) on top with a flexible wire attached to it. Coming off the tube is a L shaped arm that the common is hooked to. At least that how I'm envisioning it. Tried to coming up with a simple way to not require wires going to the floats, but given the short distance they'll move I don't see it being a problem. I guess i could have two spring loaded arms that touched the disc, but it just seems harder. This arrangement allows it to be easily shoved inside an external pipe, and keeps all the wires and such inside.
co de pen den cy
Function: noun
Date: 1979
Old 06-13-2009, 07:05 AM   #47
Duh, the disc should be on the tube, not the float. Keep the float as light as possible. Now I just need to figure out how to build this thing. Foam's a bit crumbly, but my bandsaw cuts it neatly enough. Used the Easter egg dunking approach to coat it, and that stuff should prevent crumbling anyway.
co de pen den cy
Function: noun
Date: 1979
Old 06-25-2009, 02:18 PM   #48
I've been doing a lot of reading about the Arduino microcontroller base and it's amazing what you can do with that stuff with such little effort. It's giving me so many ideas for this! A full LCD setup with capacitance sensor. Ooo!
- Kyle
Old 06-25-2009, 03:13 PM   #49
Awesome. I'll take a look. I dimly recall an ODBII project used an Arduino...I think. Thanks for the heads up.
Oh, yeah, my oil tank project's being held up by the limited selection of tubing sizes I can get locally. Lowes has a pretty good selection so I'll just grab some when I go near there next.
co de pen den cy
Function: noun
Date: 1979
Old 06-25-2009, 03:43 PM   #50
They make one that uses VSS and injector pulse. Can't be worse than a kiwi.
http://ecomodder.com/forum/opengauge...-computer.html
An actual ELM327 uses RS232 for communication. There is no reason why you couldn't build a custom scangauge type system.
- Kyle
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 11:17 PM
Engine Types danb86 Fuelly Web Support and Community News 3 09-11-2009 01:54 PM
prices vs posts here... slurp812 General Fuel Topics 41 12-19-2008 09:23 PM
Sterling Heat pump Steve6f8eh Experiments, Modifications and DIY 4 07-29-2008 01:42 PM
Compression Tester krousdb General Maintenance and Repair 7 07-12-2006 02:59 PM
