DIY floats - Page 2 - Fuelly Forums
Old 05-19-2009, 05:29 AM   #11
I'm surprised owners of big tanks don't just do it experimentally: measure as they pump in (or out) known amounts of fluid. The oil delivery guy would kill me if I made him stop every 50 gallons (or whatever). My oil tank isn't shaped all that funny and I know the angle. I know it doesn't matter ultimately, but it sounds like fun. I also have to account for the axis of the float line not being quite vertical. I used to do a lot of computational geometry at a video game place I worked so this isn't so hard. Easiest is probably to just make a 3d model of the tank and do it numerically, turning the model into very thin horizontal slices. I can already feel the wheels turnin'. Yes, I admit what you've all suspected: I have no life.
Trying to figure it out if you couldn't verify the tank's exact shape or the angle it is buried at...now that sounds hard!!
co de pen den cy
Function: noun
Date: 1979
Old 05-19-2009, 05:31 AM   #12
Originally Posted by dkjones96 View Post
About the single float idea... You could use a float with one strong magnet on it to activate small magnetic switches, like these. That would take up less tank space and they are 2 for a buck.
That is a fantastic idea. I was put off by the tilting float switches a bit because of the need to run all the dangly wiring. And it's cheap. If I put a few magnets in the float I could arrange it so that one switch is always triggered (or just space more switches properly). Magnet doesn't even need to be inside the float as it can dangle beneath.
And they're from The Electronic Goldmine! Just the excuse to order from them I was looking for. Have to make the most of the shipping and handling charges, don't ya know.
co de pen den cy
Function: noun
Date: 1979
Old 05-19-2009, 08:00 AM   #13
What is the distance of travel for the tank?
Tap the outlet line and run a clear hose up to the top of the tank. Then you can see the level.
ecofarmer is offline   Reply With Quote
Old 05-19-2009, 08:06 AM   #14
Unfortunately, he said it was a crawl space oil tank so I doubt seeing it will be that easy. However, he could do that and put the float in that external tube so if a switch ever needs replaced, needs adjusted, or breaks it isn't sitting inside the tank. Then it won't matter if the oil put in there is ever conductive too.
I did think of using one of those mower fuel caps that have the float and the gauge on them but that is very dependent on how deep the tank is.
- Kyle
Old 05-19-2009, 08:12 AM   #15
I need to measure it (pain to get into the crawlspace). It's a sideways 275 gallon tank, so not too tall. Right now I have a clear tube off of a tee fitting, but to see it I use a camera. I considered a float system with a tall rod to get it upstairs (the room I want the indicator in is next door to the tank). I could still do that I guess. Need a good source for a clear pipe section. Let's see...the rod would have to be somewhere around 6 or 7 feet I guess to get it up to a convenient viewing height. That's pretty long. Need to be light or the float would have to be big.
My first attempt was using the trapped air in the tube and a manometer to measure the pressure changes but it didn't read consistently.
co de pen den cy
Function: noun
Date: 1979
Old 05-19-2009, 08:24 AM   #16
If you were going to use a rod, there's probably no need to reinvent the wheel, just add a rod to this:
I imagine that a fiberglass rod like the kind used for driveway reflectors could do the job well but might be heavy. Else, if you could get a really long drinking straw, that would be lightweight and stiff enough (given that you use a pipe as a housing).
Old 05-19-2009, 08:31 AM   #17
I guess I could join a couple rods together. Still seems heavy-ish. I like the idea of having an electronic one so it can flash when it gets low. That setup uses a lever to get the travel height down. Not that I couldn't use that as well.
Spent a minute listing all the approaches I could think of. Did I miss any?
float with visual indicator
camera on fluid tube
optical multiple sensors (oil changes transmittance)
optical single sensor (axis along height of tank)
magnetic switches (with single or multiple floats)
optical switches (with single or multiple floats)
mechanical switches (with single or multiple floats)
tilt switches
resistive measurement at multiple points
capacitive measurement at multiple points
weight measurement
pressure changes
differential flow meters
ultrasonic distance measurement to fluid surface
variable capacitance (two nested pipes)
linear or swinging arm variable resistor sender unit
co de pen den cy
Function: noun
Date: 1979
Old 05-19-2009, 08:35 AM   #18
What about modifying an automotive fuel level sender?
http://www.amazon.com/Sunpro-CP7583-.../dp/B00029JXMU
Old 05-19-2009, 08:38 AM   #19
That's definitely worth consideration. Getting option overload!
co de pen den cy
Function: noun
Date: 1979
Old 05-19-2009, 09:01 AM   #20
Hooking whatever I go with externally is a great idea! I would've needed to remove a 4x8 OSB sheet to put it in the tank proper. The floor's unfinished in there but it'd still have been a real pain.
co de pen den cy
Function: noun
Date: 1979
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 11:17 PM
Engine Types danb86 Fuelly Web Support and Community News 3 09-11-2009 01:54 PM
prices vs posts here... slurp812 General Fuel Topics 41 12-19-2008 09:23 PM
Sterling Heat pump Steve6f8eh Experiments, Modifications and DIY 4 07-29-2008 01:42 PM
Compression Tester krousdb General Maintenance and Repair 7 07-12-2006 02:59 PM
