Cylinder Deactivation - Page 6 - Fuelly Forums
Old 11-09-2007, 06:18 PM   #51
Originally Posted by rh77 View Post
At idle, deactivating the 2-cylinders that worked together yielded in a very unbalanced combustion process, and caused the engine to rock violently forwards and backwards. The only way I could get smooth operation was to run the vehicle at engine speeds upwards of 4000 RPMs. The "LS" engine is a transversely-mounted 4-cylinder that fires at 1-3-2-4 – meaning that cylinder #1 combusts, moves downward, then the same for #3 (probably together). Then the cylinder moves back upward into the compression cycle while 2 and 4 fire. Cylinders 2 and 4 are at Top-Dead Center, when 1 and 3 are at their bottom-most position, etc. Basically there would be a firing of the top 2 cylinders (#2 and #4), then a long pause when 1 and 3 came back up and then down, creating very unbalanced sequence of events and a rocking sensation. This wasn't noticed at higher RPMs because the cylinders were coming back around quick-enough to not create a significant vibration.
I know this is an old thread. But given the fact that a new link was made to it from a new thread about cyliner deactivation, I thought that I should clear something up here. Specifically, this is NOT right about the firing of an inline four cylinder engine. Cylinders 1 and 3 do NOT fire simultaneouly, or even move in the same direction with one another (ie TDC and BDC does NOT occur simultaneously). The same goes for cylinders two and four. Rather, cylinders 2 and 3 move together with each other, and cylinders 1 and 4 also move with one another. BUT, cylinders 2 and 3 are 180 degrees out of phase with cylinders 1 and 2. So while 1 and 4 are at TDC, 2 and 3 are at BDC.
Also, although 1 and 4, and 2 and 3 both move as pairs, they do NOT fire together. Basically, when one cylinder of the pair (1 and 4, or 2 and 3) fires, the other is in intake stroke. In this manner, you get the firing order of 1342 (NOT 1324) for a typical inline four.
Therefore, in order to deactivate two cylinders in the smoothest manner possible, it is necessary to deactivate every other cylinder to fire. This means deactivating either one and four, or two and three. Deactiating one and three, or two and four will result in EXTREMELY rough running.
Old 11-09-2007, 06:37 PM   #52
It's been forever since I did that test, and background research.
If I remember properly, I tried a variety of cylinder pairs and ended up with the smoothest two.
The main conclusion to draw from the whole experience is that the Oxygen Sensor is expecting more burnt-fuel to pass by, so more fuel enters the equation. If an engine management computer in involved, there might be some potential here...
Old 11-10-2007, 11:16 AM   #53
Head temps
Another issue that is sure to eventually rear its ugle head is head warpage due to thermal gradient issues. Aluminum heads aren't going to tolerate one cylinder being cold without gaskets failing prematurely.
My thought (although clearly not a DYI) would be to continuousy rotate which cylinders are being "killed". But that would get seriously complex given the mechanical issues.
Now back to thoughts of retrofiting my Gen 2 Camry (wagon) with a plug-in Hybrid ...
ss54 is offline   Reply With Quote
Old 11-13-2007, 06:47 AM   #54
Sorry to jack the thread but... I read some folks opinions on removal of connecting rod and pistons for deactivation and wanted to share an experience. My dad who taught me all of his redneck engineering, once made a 2 cylinder VW that lasted over a year only because it was on its last legs to start with. (Case threads were stripped). At any rate, he pulled two pistons out because of a spun bearing on one journal so it would not shake so badly. He used a hose clamp and a strip of beer can around the journal to keep oil pressure to the other journals. The car took almost a half mile to get up to 55mph, but he drove it for over a year before the case studs gave up for good. It ran smoothly, idled fine and got well over 30mpg. Thanks for everyones efforts here...cheers.
snedden is offline   Reply With Quote
Old 11-13-2007, 09:17 AM   #55
cfg83's Avatar
snedden -
This is pretty cool. I assume you are talking about a classic Beetle (pre-VW Rabbit). Can you remember which 2 pistons were removed?
Here's a stretch :
VWs are flat-4 air cooled "boxer" motors
Subarus are flat-4 water cooled "boxer" motors
I wonder if there is something in the balance of a flat-four that lends itself to stable cylinder deactivation.
This implies to me that you could :
- Take a classic VW bug
- Remove the body down to the belly pan
- Put on a super-light body shell (dune buggy or ?!?!?)
- Add light-weight bucket seats
- Remove 2 cylinders
=> Have thrifty 2 cylinder VW
Reference - Flat engine
http://en.wikipedia.org/wiki/Flat_engine
Old 11-15-2007, 08:21 PM   #56
Snax's Avatar
Absolutely. Any buddy pair could be deactivated for balanced operation. That's one of the reasons Subaru has been such an advocate of the boxer motor. They don't have to reinvent the wheel every time they want to add or remove cylinders.
LiberalImage.com
I think, therefore I doubt.
Old 11-16-2007, 12:32 AM   #57
cfg83's Avatar
theclencher -
Carlo-
Minnesota State University- Mankato did almost EXACTLY what you outlined around 1980! They put a 'glass baja kit on an old VW bug, took out two cylinders, and named it the "50/50" as in 50 mph and 50 mpg. Unfortunately all the data I had on it was stolen from me, and I can't find any mention of it online.
The e-vile petrol manufactures stole it!!!!!!! Why won't you believe me?!?!?!?!?!?! It's cool to know that someone already made it. It's a natural, I guess. I wish the Kit-Car market was still bug-based instead of custom-tubular-chassis-super-expensive-design-based. If it was a Master's thesis, it should be on file in the archives.
This is also why I wish Subaru would offer econobox 2WD cars. They have 4-banger cylinder-deactivation sitting in their lap!!!!!
Regarding lost cars, I have the same problem with the "Ford Gnat" I saw at an LA auto show in the late 70's early 80's. It was designed by Ghia and now that I think of it, was practically a pre-CRX, or a pre-Metro. It was maybe a little bigger than a Fiat 500 and it was super tiny cool. I couldn't even find it at the Russian concept car site you used in other threads.
Old 11-17-2007, 08:19 AM   #58
Snax's Avatar
What? You don't want to see this of Ferraris and Porsches?
As far as Subaru is concerned, they went to the AWD-only platform in 96 or so. There are definately some pre-96 FWD Imprezas out there that might be worth exploiting.
LiberalImage.com
Old 11-17-2007, 01:45 PM   #59
cfg83's Avatar
Snax -
The thought hadn't occurred to me, but whyyyyyyyyy not!?!?!?!?!
[I]
I didn't know that. Subaru is so funny. They have their "niche", but if they want an MPG contender, they need a 2WD option. Econo-boxer-engines for the rest of us!!!!!
Old 11-17-2007, 04:19 PM   #60
Hmmm jumping in here late I guess, but I have a few things to add.
First off, unplugging the injector is just a bad idea all together for your engine. Your valves will still be opening and closing and believe it or not they need fuel to cool down. If you run it long enough like that you are going to burn your valves up.
Displacement on demand will actually stop the valves from moving so they don't burn out. Its also really lame (at least on SUV's) it more or less will only kick on when you coast, if you blow on the gas pedal it will go back into v8.
equate975 is offline   Reply With Quote
Facebook post not working? jwalker343 Fuelly Web Support and Community News 15 07-12-2014 05:08 PM
Problems with Total Miles Driven bmalachuk Fuelly Web Support and Community News 4 05-02-2011 04:15 PM
Fill up more than one vehicle with SMS GillaFunk Fuelly Web Support and Community News 4 04-12-2011 01:48 AM
No MPG on next tank after partial fuel-up ? insightfulone Fuelly Web Support and Community News 1 04-18-2010 12:54 PM
Hey I'm a new member with a Festiva GasSavers_Kraig Introduce Yourself - New member Welcome 24 08-21-2006 06:17 PM
