CRX HF '91 Federal ECU in '88 CA? - Page 2 - Fuelly Forums
Old 02-13-2008, 05:13 PM   #11
Originally Posted by Brian D. View Post
Gone through another tank yet? I'm very curious about all of this. I'd also like to figure out once and for all whether or not there really are HP differences between the 1988 and 1991 model CRX HFs. Does anyone have any actual manufacturer's information on this?
http://www.autos.msn.com
I had thought that the 90-91 had 70 HP but I checked autos.msn.com and they still were 62 so no difference there. This experiment will have to be postponed until the purchase of a supermid. The last tank was not so good 43.7 but I just fixed the A/C and was using it a bit in the mini heat wave this week. I'm still dialing in the car and making adjustments so any conclusions made would be weak at best. It's worth it just the way it runs with the federal. Of course maybe my old one was bunk.
No conclusions here but for $25 or so I'd think it would be a good time to get a spare for the future anywayh
FritzR is offline   Reply With Quote
Old 03-28-2008, 09:26 PM   #12
I am having a friend from Honda-Tech chip me an ECU to use in my HF. I originally wanted a FED ECU for my CA car. He told me to get him an auto LS integra ECU, and he burnt me a custom mapped chip for gas mileage. He said it should help with a little more power too.
crxbart is offline   Reply With Quote
Old 03-29-2008, 12:49 PM   #13
Tell me your results when you get done! I think the main difference between the fed and the CA hf is the ecu causes the car to run better at low rpms and that the fed has a shift light. I don't think I'd want the fed transmission because at freeway speeds around here I get the best MPG at 65 MPH, thanks yoshi. At 65 I get 60MPG cruising the freeway holding the gas steady up and down the hills. At 55 MPH I can get 65MPG on a flat but I have to gas it up hills so I am not going 45 in a 65 zone and overall I end up with less MPG cruising. If I lived somewhere flat the federal trans might be worth it. These are numbers from my supermid so they do not count any accelerating on the onramp, slowing for traffic etc...
Old 11-11-2009, 08:37 PM   #14
Federal PM8 ECU
Do the part numbers differentiate between the Federal and California PM8?
Some end in a 20, 22 and 30. Some serial numbers start with 660 and others with 661. How can I be sure I get the 49 state version?
quartersawnoak is offline   Reply With Quote
Filter by Imperial vs. U.S. Gallons? bvz2000 Fuelly Web Support and Community News 4 05-02-2013 08:33 PM
Old Tires, Higher RR? Bill in Houston General Fuel Topics 16 05-26-2007 05:53 PM
The great news about the EPA's new tests repete86 General Fuel Topics 8 02-07-2007 07:01 AM
E-85 and EPA rating zpiloto General Discussion (Off-Topic) 7 09-26-2006 07:04 AM
