Where to splice the wires!
I removed the cruise control cover and the circuit board to see the drive motor. The drive motor is on one side and the magnetic engager is on the other side.
I drilled a 0.188 hole in the rear of the housing near the top and ran the (2) wires through and sealed the hole with 5 minute epoxy. If you use silicone (RTV), use the sensor safe type to eliminate the possibility of circuit board corrosion from the fumes.
Be sure to seal the firewall where the wires go through.
I cut the red wire to the motor and attached the red lead from the circuit board to an 18 gage red wire. This red wire is power and it is soldered to the toggle switch pole.
The wire from the motor is red and an 18 ga wire (I chose orange) is attached. This orange wire from the motor is soldered to the togle switch other pole. I used a double pole mini switch and used both contacts to increase the amp capacity of the switch. (not necessary)
I removed a switch blank, there are extra places for switches on the left side of the steering wheel... the panel that has the mirror controls, and drilled a hole, mounted the switch and snapped the switch blank back in place.
My logic is when the switch is in the down position (ON) the motor is connected normally. When the switch is in the up position (OPEN) the motor is frozen in place.
