coolant sensor mod - Fuelly Forums
Old 02-06-2006, 05:49 PM   #5
the elegance of this
the elegance of the above approach is it's fully automatic, and relatively self-limiting.
the down-sides are that it's (a) non-adjustable on the fly, and (b) the "warm" engine temp isn't 100% accurate (though if you're just going by the temp gauge, he says it's in the usual position).
my idea was to do this mod using a variable resistor - potentiometer - in place of the second WTS/resistor combo.
that way i can fully dial in as much or as little "heat" as i want the PCM to see, and then switch it off once actually warmed up, to revert to the "un-modified" coolant temp signal.
but i'm no electronics expert. (i never had any electrical classes at school.) if you have a look at the thread on the teamswift site, you'll see me asking some pretty basic questions, as i learned about how this mod works. in particular, i needed to understand the difference between resistors wired in parallel vs. series. (one halves, the other doubles the sum of the values of the resistors, assuming equal value resistors).
i have a decent grasp now, but could use some help with the potentiometer idea. i've already scrounged one to test, plus a switch to take it in/out of the circuit, but could use some help if there are any electronics gurus here.
anyone, anyone?
i'm looking to clarify the wiring before i try it out.
Can we have a 'top cars by mpg' section? MpgWars Fuelly Web Support and Community News 2 02-02-2012 11:26 PM
Location filter? BDC Fuelly Web Support and Community News 11 09-05-2009 01:16 AM
Reporting capabilities via SMS? hidesertmlb Fuelly Web Support and Community News 4 09-02-2008 12:02 AM
Stations that sell E10 (read: Stations to avoid) GasSavers_DaX General Fuel Topics 46 01-10-2008 03:46 AM
I issue a challenge!!! Matt Timion General Discussion (Off-Topic) 32 01-29-2006 05:28 PM
