computer fan turbo? - Page 3 - Fuelly Forums
Old 06-20-2008, 10:35 AM   #21
flapdoodle's Avatar
Things I have found that need to be taken into account...
The vacuum gage has been found to be the best indicator I have of FE. With the ram air hose installed it was good for a solid 1 MPG. But when the warm air intake from the exhaust manifold is activated there can be NO ram effect.
At the speeds I drive to and from town (45MPH) the vacuum runs about 15 inches of mercury. That translates to 7.367311 PSI. It takes energy to create that, and anything I can do the help means greater economy.
One thought is to use the air from the radiator fan to help. It is already nice and toasty (but less than the temperature setting on the intake heater which I measured at 133 F), and the energy to run the fan has already been accounted for, so I figure it might give a slight boost. All I would have to do is reroute hoses.
Every other form of intake uses power, be it hood scoop, or electric blower. Turbos are a different thing all together, but do create a little back pressure, hence the need for big exhaust pipes.
Old 06-20-2008, 11:03 AM   #22
random thought from reading above. Ram air to air/water intercooler(warmer really) to manifold. Would be useless at low speeds, but at higher speeds down the Interstates or highways, the ram air pressure should negate the drop across the a/w IC while still providing hotter air that's pressurized more than what the motor pumps. Does that make sense?
almightybmw is offline   Reply With Quote
Old 06-20-2008, 11:52 AM   #23
flapdoodle's Avatar
Yes, it does. I was hoping the cooling fan might give a little boost, and at speed the air would be forced through the radiator with a far greater area than the tiny amount going around the cowling. Insects and birds would be filtered out by the A/C condenser.
Old 06-20-2008, 12:00 PM   #24
....lol.. I use my radiator to filter small game! lol sorry, that made me laugh a lot.
Scangauge 2 vs Supermid dcoyne78 Hypermiling 11 01-04-2011 06:06 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 04:51 AM
Need help with stickers for the wheel skirts lovemysan General Fuel Topics 2 11-15-2006 10:30 PM
