06-19-2008, 08:26 AM
Computer fans don't create much boost.
http://www.goldmine-elec-products.co...?number=G16216
That fan creates 235 cfm @ 0.768 static pressure. I'm using the fan for a flow bench i'm building and the cfm and pressure ratings are almost perfect for what I need. That, combined with a hot wire air flow sensor, will make for a pretty good bench when I start doing custom head work for fuel economy.
- Kyle
06-19-2008, 08:27 AM
I whipped up a plate with a barbed tubing fitting and measured two different 80mm computer fans with a manometer. Both read the same at 1/4 inch of water. That is about what I expected. I had been interested in this before (after I abandoned using an array of them for radiator cooling) and feel that gains could be made by reducing pumping losses rather than a "supercharger".
My car is very sensitive FE wise about intake restrictions. I had thought of a square box that replaced the original aircleaner housing and fit atop the carb. It would have 10 fans arranged around an inner box and two ram air hoses on the outer box. I can make a drawing if anyone is interested.
06-19-2008, 01:37 PM
You can make a hood scoop to pressurise this intake, the bigger the scoop or mouth the greater the pressure will be, and its free, well almost, it will create drag if its making pressure.
I think the main goal is to reduce something called parasitic drag on the intake.
06-19-2008, 05:17 PM
i also looked in to this for performance and i came across a product in the internet
http://images.google.co.uk/imgres?im...icial%26sa%3DN
maby this will be some help to you
Russ . .
I also have information on my HH-O Forums
06-19-2008, 08:37 PM
That product claims on the dyno graph to give over 50hp, thats just to much of a claim, even the 10% is too much, if it could must 1 or 2% I would be happy with that.
06-20-2008, 03:46 AM
You are referring to a ram air intake. It stops or "stagnates" the air, whose total pressure is the combination of static and dynamic pressures.
Not really worth it, IMO. I once calculated the difference in pressures, it was pretty low. I may revisit that calculation though, to refresh my memory.
06-20-2008, 05:03 AM
I did some ram intake figuring a month or two ago and was figuring that at 60mph, it would only get about .1 PSI..... however, some performance sites claim that this is enough to nullify the pumping loss/restriction of the air filter.
I have the front bumper off a bonneville SSE and am thinking I might mount it on marvin and use the driving light holes for ram intakes.
Anyway, yes, computer fans = way too weak... they're even too weak to effectively cool CPU heatsinks, they don't push the air into the fins hard enough. I have a couple of relatively small heatsinks set up with 25cfm centrifugal blowers, and because they can push a couple of PSI, they work better than 80cfm axial "howlers" on huge heatsinks. (For the technically minded, this turns a .50 c/W heatsink/fan combo into a .25 c/W or better)
However, the power draw of that type of blower is about equivalent to an axial fan of 3x the CFM.
A thing to beware of while experimenting is that you might find something that appears to give you 10psi of boost at idle, but as soon as you crack the throttle this drops to nearly nothing.
For example, some of the most powerful centrifugal blowers you can get hold of at a consumer level are leaf blowers. A typical 350CFM leaf blower will give between about 1 and 2 PSI of boost at mid RPM. Try to go WOT and 6K and it prolly won't keep up still, figure about .5 PSI there.
06-20-2008, 07:09 AM
06-20-2008, 07:39 AM
#19
I have heard the Pressure is low even on a ram intake but those funny cars are doing 250mph, and because air gets hard to push the faster you go I guess at those speeds it must make some decent pressure and reduce pumping loses.
06-20-2008, 10:23 AM
#20
That's pounds per square foot isn't it, not square inch, 144 sqin to the sqft, = 0.03 PSI at 30mph...
