08-05-2006, 12:12 PM
brake temps -how hot is too hot?
I'm planning to install a set of moon disc hubcaps. I've read that these could cause overheating problems (no vents in the cap to allow cooling).
I have an '05 Civic coupe (front disc/rear drum), and using a Fluke mini 62 IR thermometer got the following readings:
85F all four corners (ambient temp after sitting in garage overnight)
after my 37mile commute (30mi highway, 7mi stop-n-go city):
(LF)120F (RF)119F
(LR)112F (RR)112F
I'll monitor the temps over the next few days to establish a baseline, and again when I install the moon discs. But my question is how hot is too hot, at what point should I expect to encounter brake fade and/or rotor damage (warping)?
08-05-2006, 12:40 PM
I'm no expert but I would expect well over 200F before warpage would be a problem. If Im not mistaken, warpage is caused by extreme tamperature changes in a short period of time. Like spraying cold water on a hot rotor.
I doubt that a gassaver would overheat thier brakes, moon disc hubcaps or not.
08-05-2006, 12:59 PM
I wouldn't worry about it unless you do some hardcore 100-0 braking.
By the way, welcome to the site! Feel free to start a thread in the introductions forum and tell us a little bit more about yourself and your civic.
08-05-2006, 01:07 PM
My Geo was dragging a pad and heated the rotor and the wheel got hot too but it didn't damage the rotor it cooked the bearing - started rumbling.
08-05-2006, 05:03 PM
at around 380F metal will turn that pretty blue color, depending on the alloy of steel, and I haven't seen many warped rotors that didn't have signs of blueing, and have seen some pretty straight ones that were blue.
for an 05 civic, I think that has a 5 lug bolt pattern wheel, correct? the new civic hybrids have near disk, vented alloy wheels that are honda's 5 bolt pattern.
08-05-2006, 05:12 PM
05 civic was still 4x100.
08-05-2006, 05:22 PM
Thanks for the replies; I'll follow-up with a post showing the delta in temps after the discs are installed. As kdb surmised, I'm pretty easy on my brakes so it might not be a huge difference; either way it'll be neat to see the numbers.
Ryland, my '05 Civic is the base coupe with 14" 4x100 steelies & hubcaps.
I'll drop an intro thread tonight when I get home from work (really shouldn't be goofing off and posting now, but...
08-05-2006, 05:29 PM
then Insight wheels will fit perfectly, www.carpart.com is where I search for things like that, when I need to get new tires I think I'll look at some insight rims, around 11 pounds each for near disk alloy wheels, skip the hub caps and steel rims, save weight and be more airodinamic!
08-05-2006, 05:39 PM
Or pimp some HX rims,
08-05-2006, 07:05 PM
he has the same car as me! just an auto instead of a 5spd
buty his gears are more tuned for efficency than mine grrr  and he has other goodies like keyless and an armrest ;(
