Bilge pump mod - Fuelly Forums
Old 03-23-2007, 08:48 PM   #1
lovemysan's Avatar
Bilge pump mod
I read about this guy swapping a 500 gph boat bilge pump on to his sentra in place of using his water pump. Of course he did it for horse power. He daily drove the car for 2 weeks after and reported that it did not overheat. I never went back and looked at the thread for more info.
Someone should try this a cheap electric water pump on there car and no acc belts.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 03-26-2007, 03:01 PM   #2
Member
Don't forget that the power to run an electric pump comes from the alternator. It isn't free! There are potential mpg gains but they must outweigh the inefficiency of having to drive the alternator to provide juice to run a pump, over the engine driving the pump in the first place.
markweatherill is offline   Reply With Quote
Old 03-26-2007, 03:36 PM   #3
Perfect for someone who runs without an alternator though. I didn't know there were inline bilge pumps - the one in my boat has to be submerged before it will pump - there's only one hose fitting on it: "out".
Old 03-27-2007, 06:14 AM   #4
Mark, I think that the idea is that while you are cruising along a flat freeway at 55mph, there's really no need for your water pump to be turning 2000 rpm. The pump is sized so that it pumps enough water for you to pull a trailer up a mountain on a 120 degree day, and it pumps that amount of water all the time. A thermostatically controlled electric pump could be sized more appropriately for a driver's particular use, and would only run when it needed to. It's the same idea as the electric fans on car radiators.
Old 03-27-2007, 07:04 PM   #5
lovemysan's Avatar
I'm not going to try this but someone else might. I wouldn't recommend it on a daily driver either but it would be an interesting experiment. I'm sure there is a cheap marine pump available somewhere that would work. Sadly I don't remember the particulars anymore. It seemed to have been some type of marine pump purchased at walmart for around $25.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 03-27-2007, 07:12 PM   #6
The motor is a brushed motor in those pumps and will wear out eventually. The one advantage is that you can maintain a constant water flow and that can be helpful if you are running hot and are operating the engine at low rpm because the pump can be running at a higher volume than the belt driven water pump would be running plus at higher RPM you don't overspeed the water pump and cavitate it thus saving power etc.
Cost of motoring UK & US Draigflag General Fuel Topics 13 12-12-2013 05:22 AM
km/l possible? Scottrates Fuelly Web Support and Community News 4 10-05-2010 11:14 PM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 01:15 AM
RSS feed for Fuel Tip Page randomic Fuelly Web Support and Community News 3 08-22-2008 11:55 PM
Do other drivers ever get pissed off at you? LincolnW General Fuel Topics 174 10-26-2007 09:47 AM
