Anyone use a SMALLER intake tube? - Page 2 - Fuelly Forums
Old 07-18-2016, 03:10 AM   #11
Usually sensors reprogram to improved air flow automatically. Some cars simply require a disconnect from the battery and a sensor will relearn within a few minutes when the engine is running
CARiD is offline   Reply With Quote
Old 07-19-2016, 04:04 AM   #12
By the way here's a good article that covers high capacity filters and air intake tubes: Can an Air Intake System also Increase My Fuel Economy?
Old 01-15-2017, 08:38 AM   #13
As for smaller intake tube size smaller was better for fuel mileage back when the fuel was mixed with the incoming air to keep the fuel suspended and at a higher velocity to give some ram effect. But with fuel injection the intake only has to deal with air volume and more air is better. so the larger air intake the better for MPG.
58DeSoto is offline   Reply With Quote
Old 01-15-2017, 04:37 PM   #14
The Civic VX used a smaller diameter intake tube than the other models.
Old 01-15-2017, 05:41 PM   #15
as for the smaller tube on the vx probably smaller because the vx has smaller injectors 190cc vs standard 240cc as well as smaller intake valves. still the larger tube would still allow more air in but the log jam is the small valve
