Anyone experiment with high flow mufflers? - Page 4 - Fuelly Forums
Old 11-06-2007, 10:25 PM   #31
omgwtfbyobbq's Avatar
I think it's related to constructive interference at different engine speeds, so switches w/ access to different exhaust lengths would be the best. Kinda like ACIS... But, for any new car it's easier to just optimize via exhaust valve openings. Maybe it's easier to drop one of those new fangled engines in than screw around w/ some funky system?
Old 11-07-2007, 04:20 AM   #32
ZugyNA's Avatar
Originally Posted by Coyote X View Post
They got blown off the exhaust when I started driving it though so I have no idea if they helped mileage or not. I kept meaning to make another set and clamp them on a lot tighter but I haven't drove that car much lately and kind of forgot about it.
I do think that reducting the exhaust flow will help mileage on the low end and probably kill your power and mileage on the top end.
Yep. Keeping it on the exhaust is an issue. Thats why the tip that JCWhitney sold was supposed to be welded on. It also had a spring loaded butterfly that opened up for WOT.
Old 11-07-2007, 06:15 PM   #33
Originally Posted by ZugyNA View Post
I had nothing but a fiberglass filled exhaust tip and a cat on a 3L V6 and it was the best sound I've heard on a car I've owned. Much better than a glasspack muffler. Problem is it rusted out after 3 yrs or so.
I just like to hear the motor. I am kinda old school. Don't like automatics either.
Old 11-07-2007, 09:02 PM   #34
Question
Which V-6 in what vehicle, and you wouldn't by chance have a recording of it, would you?
Dynamically Aero is offline   Reply With Quote
Old 11-08-2007, 04:42 AM   #35
Originally Posted by slurp812 View Post
I have this
http://www.gassavers.org/garage_imag...ry1wxmulun.jpg
As others have stated, it only helps if I am into the throttle way beyond FE driving. But it is fun once in a while. I am a reformed psycho-driver. I had 8 speeding tickets in a 3 year period. I had to stop. I was driving way too fast for my age. I am kind of a ricer. I will put the same thing on my next japan made car also. I like the way it sounds, and I like the feedback I get from the sound. Not all gray haired drivers drive slow.
That Accord goes fast enough to get a speeding ticket?
1994 Geo Metro
1998 Buick Regal GS
1999 Chevrolet C2500
1998 Corvette
Three6Eight is offline   Reply With Quote
Old 11-08-2007, 06:49 AM   #36
A car requires back pressure to make torque. The smaller the engine, the more back pressure is required. For the OP I would leave the stock exhaust alone, unless it needs to be replaced. You will burn more gas trying to get the mass of the car going if you lose torque on the bottom end because of a 'bigger' or more free flowing exhaust.
srt-4 is offline   Reply With Quote
Old 11-11-2007, 08:51 AM   #37
First off, most people never see an increase in mpg when the car has more power, resisting that urge is one tough challenge, perhaps more so if you haven't driven 10-20 years with an impeccable driving record.
Most people, once the power is there, git it.
Hence they end up getting less mpg and they wonder what it was all about?
Theoretically speaking, increasing SPARK or AIR would yield better mpg IF you can keep your foot off the throttle, but a self-admited ricer? It takes a lot of self-discipline, kind of like those old grey-haired guys you always see driving the super fast cars doing the speed limit, about like that. Oh yes, age helps.
Now to install a muffler...
With a high flow exhaust system you need more than a muffler, you need pipes and a high performance manifold, in addition to a second cat, what you really need is called 'dual exhaust with headers,' and this is impractical because the cost of this runs 4-6-700 DIY and you're easily looking at a few thousand with a mechanic doing things, and of course muffler work usually requires welding.
And no, a muffler alone won't do squat.
For all that and the purpose of experimenting you're as well off installing Double platinum spark plugs, some decent high performance spark plug wires (such as Accel's 8mm or better yet Taylor 10.2mm), and a high performance cap and rotor.
DIY will set you back 1-200 and now that you're getting serious SPARK you can see for yourself if the +power = +mpg line of thinking is right for you.
But no, in most cases it will not increase mpg, but as much if not more so because once folks feel the power there's not much doing.
The trick is to resist the urge and actually use less fuel than before the upgrade, give it less throttle to accomplish the same acceleration means the increase in SPARK (and/or AIR) does the work while less fuel is used in the end.
The decrease in torque has less effect than the increase in HP, in the battle of horsepower vs. torque it is the horses that always win. Yes, you can manipulate torque and horses to a point and even to the extreme, but no matter how well manipulated a torqued setup gets, it's the vehicle with the most horsepower that wins.
Although impossible in a real life application (because horses and torque can't have one without the other), in the following case example:
A car with 100 horsepower and 0 pounds of torque
vs.
A car with 100 pounds of torque and 0 horses.
The car with 100 horses would win, every single time.
Yes, if it were possible, and we agree, leave the muffler alone
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 01:04 AM
"The End of Suburbia" video on youtube kickflipjr General Discussion (Off-Topic) 44 04-18-2007 03:48 PM
Change a Light, Change the World rh77 Automotive News, Articles and Products 23 01-03-2007 10:53 AM
