Anyone experiment with high flow mufflers? - Page 2 - Fuelly Forums
Old 11-03-2007, 07:29 PM   #11
Originally Posted by smay665949 View Post
If you are running a V8 truck I know any exhaust mods will increase FE and power. I am not sure if small economy cars will benifit.
The same is true with more performance-oriented four cylinder engines like Honda's DOHC VTEC engines. Not sure about economy engines, though.
Old 11-04-2007, 04:51 AM   #12
ZugyNA's Avatar
http://www.spiralturbobaffles.com/semiinfo.html
http://www.aeroexhaust.com/
http://www.bladeyourride.com/
At ATDS the Blade was tested on a 2004 Honda Civic using the EPA 511 Testing Protocol, which is a combination of the EPA's FTP–75, and Highway Fuel Economy Tests. EPA 511 includes the measurement of three baselines and three tests. The EPA 511 is considered statistically valid.
http://www.bladeyourride.com/Blade-511-Results.html
The same 2004 Honda Civic was road tested for 6-months and the average gas mileage increase has been aproximately 30%.
http://www.jegs.com/webapp/wcs/store...44819_-1_10265
Old 11-04-2007, 08:24 PM   #13
Liberator for all of you semi owners.
Dynamically Aero is offline   Reply With Quote
Old 11-04-2007, 10:34 PM   #14
cfg83's Avatar
ZugyNA -
Hmmmm, I never heard of the blade. It's got that "easy install" appeal. But it isn't compatible with my Saturn :
Attachment 1026
Couldn't I just cut my stock exhaust tip to match the first or second example?
Here's a longggggggg thread debating the snake-oil factor of the blade. It includes posts from a blade representative (look for posts from a guy named sabertec) :
Blade Your Ride
http://www.links4jeeps.com/phpBB2/vi...&postorder=asc
I'm gonna do more homework on this. I would be happy if it had +- 0 effect on MPG but helped emissions.
Old 11-05-2007, 12:16 AM   #15
ZugyNA's Avatar
JCWhitney sells or sold a muffler tip that uses a spring loaded butterfly to restrict the exhaust during cruise and increase mpg.
The spiral mufflers reduce back pressure and might increase exhaust flow by spiraling the gases.
The Jegs spiral muffler looks like the best deal...not so sure it is sized right for a 4 cylinder though.
When you see a bunch of idiots piling in on a subject and doing the ridicule thing...run don't walk. Just because it's the internet doesn't mean only bright people are on it.
You test things by buying or making them, installing them, and then checking your resulting mileage.
Old 11-05-2007, 01:07 AM   #16
cfg83's Avatar
ZugyNA -
You test things by buying or making them and then checking your resulting mileage.
I know, but we do the same sometimes, . Also, it's important to do due-diligence. I think it is *very* interesting that the blade representative stuck around and took the punishment without losing it, so that's a plus for him.
Old 11-05-2007, 05:27 PM   #17
Talking
Originally Posted by Three6Eight View Post
I really dont want to add one to my metro because I dont want it to sound like a ricer car but if it helps with mileage Im all for it. I just wont get and oversized tip.
I have this
http://www.gassavers.org/garage_imag...ry1wxmulun.jpg
As others have stated, it only helps if I am into the throttle way beyond FE driving. But it is fun once in a while. I am a reformed psycho-driver. I had 8 speeding tickets in a 3 year period. I had to stop. I was driving way too fast for my age. I am kind of a ricer. I will put the same thing on my next japan made car also. I like the way it sounds, and I like the feedback I get from the sound. Not all gray haired drivers drive slow.
Old 11-05-2007, 06:54 PM   #18
trebuchet03's Avatar
I believe Nissan (or maybe it was Mazda) had something like that.... And Autospeed magazine either built an exhaust bypass or talked about such a system....
S/he did freak out at one point... A lot later than I would have expected... But it wasn't terrible, and s/he recomposed her/himself.
That being said... I can't argue with a lab's statement... But the EPA documents outlining the 511 protocol seem to be a bit unclear... Is the 511 their own evaluation program that they do (as the introduction states), or is it something else?
The evaluation is often identified as the ?511 Program? which refers to EPA?s testing program formerly conducted under authority of Section 511 of the Motor Vehicle Information and Cost Savings Act.
In any case... the idea of adding back pressure does make sense to a degree (too much and you'll have ridability issues).
11/12
Old 11-06-2007, 12:31 AM   #19
cfg83's Avatar
trebuchet03 -
Ok, I skimmed over the thread (12 pages!!!!) and didn't read all of "sabertec's" posts. I was looking to see how long he/she lasted, and it seems she/he was still around at the 9th page.
At $150, it's 3 times the cost of my sucker-limit, so I'm just gonna keep trolling around for information on it.
It claims to reduce emissions (mostly during the cold start-up phase?). It makes me think it has a "filter" that you need to clean, but maybe it's just back-pressuring the exhaust into the cat in order to "cook" the exhaust a little more?!?!?!?
Here's their diesel emissions gizmo that they used as the origin of the blade :
http://sabertec.org/index.html
Sabertec IDPF Technology is a breakthrough in PM filtration. Impact Diesel Particulate Filters cost significantly less that catalytic technologies, they are highly effective in filtering PM 10 and PM 2.5, and unlike conventional technologies, they are capable of working with high sulfur content fuels.
Would this IDPF thingy be directly applicable to a normal gas driven car as a post-cat device? Hmmm, maybe not, because particulate matter is not as big a problem with normal gas cars.
Old 11-06-2007, 01:04 AM   #20
omgwtfbyobbq's Avatar
At ATDS the Blade was tested on a 2004 Honda Civic using the EPA 511 Testing Protocol, which is a combination of the EPA's FTP?75, and Highway Fuel Economy Tests. EPA 511 includes the measurement of three baselines and three tests. The EPA 511 is considered statistically valid.
I wouldn't go as far as to say it's valid if they're comparing a car w/ 40k miles on it and who knows what in/on the crankcase/gearbox/wheels to whatever the EPA used to test. Weren't these the guys who said driving around at different dates/times in one of the most traffic ridden areas in CA was a legit version of the EPA test? I smell bull...
Incorrect mileage calculation? tonedepear Fuelly Web Support and Community News 6 04-04-2011 12:04 AM
"The End of Suburbia" video on youtube kickflipjr General Discussion (Off-Topic) 44 04-18-2007 02:48 PM
Change a Light, Change the World rh77 Automotive News, Articles and Products 23 01-03-2007 09:53 AM
