And we have a wiener! - Fuelly Forums
Old 05-31-2008, 03:03 PM   #1
ZugyNA's Avatar
Got a good gain with my last iso/MMoil mpg test...around a 10% gain.
I used a 5 to 1 ratio of Walmart 91% iso to 1 part MMoil.
This = 2.3 oz of this mix to each 10 gallons....3 oz to a full 13 G tank.
I use the 91 % iso because it is cheaper than Heet...it also has 9% water in it. When put together they will separate...so you need to shake the bottle before use.
If running an electric pump I'd change the ratio to maybe 3 oz iso to 2 oz MMoil. Or around 4 oz of this mix per each 10 gallons.
When I tested 5 oz per 10 G of this mix AND HHO...I had real good power but LOST mpg. So the amount used is probably critical.
Test at your own risk.
Old 06-05-2008, 09:33 AM   #2
What is MMoil?
Hipermiler
#47 on my way to #1
Old 06-05-2008, 09:46 AM   #3
flapdoodle's Avatar
Marvel Mystery oil
Old 06-05-2008, 10:10 AM   #4
You know what, I wouldn't characterise MMO as a particularly good lube, from the MSDS it sounds something like kerosene, coleman gas and varsol.... and the funny thing is that your mix kind of approaches the chemistry of "Seafoam"
Probably keeps the chambers and injectors nice and clean though.
