Alternator v. no alternator - 10% gain @ 70 km/h - Page 17 - Fuelly Forums
Old 04-13-2007, 07:49 PM   #161
Originally Posted by brelandt View Post
Anyone consider rigging up a lock and release pulley on the altenator fan belt?
Place a longer than needed belt on and have a pulley attached to a cable that when pulled would lock into place putting tension on the belt thus allowing the alt to work. Then at the press of a button or whatever else you can think up of unlock the pulleys catch and allow the belt to loosen off of the alt.
Might be way off but I'm not a spark chaser. More of a hardware person myself.
I see -- similar to how a belt-driven lawn tractor engages the cutting blades.
This may have been discussed already, but how about how the Air Conditioner compressor engages -- with an electromagnetic clutch...
Old 04-13-2007, 07:58 PM   #162
trebuchet03's Avatar
You'd need to consider alignment -- but that would work for those of us with a dedicated alternator belt :P
My engine uses 1 serpentine belt :/ It just started squealing too (well, I hope it's the belt and not the PS pump).
11/12
Old 04-14-2007, 05:44 AM   #163
I forgot about you guys with the single serpentine belts!
I have no powersteering and I'm going to remove my A/C. So I can move my alt forward to align it with the crank pulley that drove the A/C so that the water pump can have it's own seperate belt.
For you guys that can't than using an electromagnatic clutch would be the answer.
brelandt is offline   Reply With Quote
Old 04-14-2007, 02:02 PM   #164
Dracofelis: that's an awesome summary of the state of the art for people thinking about this mod.
Old 04-14-2007, 05:05 PM   #165
DracoFelis's Avatar
Originally Posted by MetroMPG View Post
For this approach to make sense financially, you would neither either (or both) of:
1) fuel that is much more expensive than it is now;
2) a supply of free or cheap batteries.
You forgot 3) A source of cheaper electrical power.
That's why I think that solar cells are so interesting. Because after you've spent the initial $$$ for them, good solar cells will usually last longer than most cars (so they aren't a "consumable" per se, more of a "durable good"). In fact, in many areas, solar can already "pay for itself" when compared to "grid power" in the home (it takes several years to get to "break even", but in many areas you do eventually get enough power savings to pay for your initial investment, after which everything is "money in our pocket"). And since the standard sources of electricity in the car are much more expensive than "grid power" for the home, solar for the car should be even more "cost effective" (i.e. theoretically have even a shorter time period for "break even").
Now I don't think that solar is the whole answer in a car. I just think that some carefully chosen (and carefully installed/mounted) solar panels might be "worth it" from a cost/benefit standpoint given a long enough time horizon. In other words, think of solar as a "durable good" type mod. A few hundred $$$ solar panel likely won't save a lot of gas, but (as long as you don't kill that savings by worse aerodynamics and/or the weight of the solar panels) it will likely start saving you a small amount of fuel (by lowering the need for power from the alternator). And eventually (after a few years), you will likely have reached "break even" (saved enough fuel to pay for the solar panels), after which all the extra fuel savings is just "money in your pocket". At least that's what I think my initial "playing with the numbers" seems to be telling me about solar panel power generation in cars.
NOTE:
There are only so many places that "make sense" to mount solar panels in cars (and those mounting spots vary with the car design). So there is a limit as to how much solar power you can get in a car (even if you had an unlimited budget to buy additional solar panels), and that limit varies with the car design (with some "vans" and other big vehicles, having a lot of room for cell mounting, and some small cars having virtually no room for solar cells). This doesn't mean it's not worthwhile to use solar (as any solar power should lower gas needed to otherwise generate that electricity), just that these limits may prevent you from solving all of your car's electrical needs via solar.
For example, the most logical place to mount the panels in my CRX, would likely be under my rear hatch window, but on top of the the internal "trunk cover" that's below that hatch. This would make the panels easy to mount, and also avoid the aerodynamic issues (as the panels would be fully within the cabin of the car). However, it also puts a pretty hard limit on how much panel space I could use, as there is only a few square feet in that area (enough for a small solar panel or two, but that's it)! And while those numbers are unique to my car design (other car designs would either have less or more space for panel mounting), every vehicle on the road will have limits in this area, as no vehicle has "unlimited surface area". And once you've reached your limit in solar panel surface area, pretty much the only way to increase your solar power, is to use more costly/efficient solar cells (and thereby get more power for each square foot of solar panel space) and/or better battery/charing circuitry (to better store the solar power still being generated when your car is turned off), and even those efficiency and storage technologies also have their limits. So eventually you will reach the limits of what you can do with solar inside a car no matter what you do.
But just because solar has limits in a car, shouldn't be a reason not to use solar at all. Because, until you reach those limits, solar could still easily "help" more than it "hurts"!
Old 04-19-2007, 11:53 AM   #166
rvanengen's Avatar
Originally Posted by SVOboy View Post
95Metro, get yourself a superMID, it's the best. Every day has become a personal FE challenge for myself, and I find that I'm really pushing it in order to do my very best and paying attention to minute details much much more.
Darin, you're the beast! I'm starting to understand the concept much better, . In any case, I will try and do some civic testing for you when I get my MID stuff ironed out. I'm hoping to have testing starting (with numbers, but fake ones) after I fill up, but who knows, my gramma will be in towne for graduation, but we'll see!
Good luck!
Do you know where to get one, and if so, are they available for an older Mercedes?
Thanks!
-- Randall
McIntyre's First Law: "Under the right circumstances, anything I tell you may be wrong."
O'Brien's First Corollary to McIntyre's First Law: "I don't know what the right circumstances are, either."
rvanengen is offline   Reply With Quote
Old 04-20-2007, 02:56 AM   #167
OdieTurbo's Avatar
Send a message via Yahoo to OdieTurbo
What's the possibility of using an electrical switch to kill the alternator? Since it's not a generator, it requires an electrical field to generate electricity, hence the wires feeding 12v to the alternator. If you disconnected those wires, the alternator should have no load. Has anyone tried this? Or shall I just bite the bullet and try it?
2005 Saturn VUE 2.2L 5-Speed FWD
OdieTurbo is offline   Reply With Quote
Old 04-20-2007, 05:55 AM   #168
Snax's Avatar
Some alternators are internally wired to provide the field with energy after the initial trigger. The only way to shut them off is to stop spinning them.
LiberalImage.com
I think, therefore I doubt.
Old 04-20-2007, 11:35 AM   #169
I agree that this should work. Do it! Do it!
Old 05-25-2007, 10:46 AM   #170
Tuggin at the surly bonds
Silveredwings's Avatar
BMW is putting their combo intelligent alternator control with an auto stop/start feature on manual geared Minis.
http://www.greencarcongress.com/2007..._apply_st.html
(though it seems to be targeted initially on the diesel versions...meaning Americans can't have one )
