Air Dam and Front Undertray - Page 3 - Fuelly Forums
Old 03-23-2007, 11:38 PM   #21
wow! one of the nicer air dam installations I have seen, Ya'll got me a bit more motivated to work on my car again!
Old 03-24-2007, 10:24 AM   #22
kps
Originally Posted by SVOboy View Post
Hondas are touchy about overheating? I haven't heard anything about it!
In early winter I put a lower grille block on my Fit, and found that in highway driving the engine temperature increased to the point that the radiator fan ran continuously.
kps is offline   Reply With Quote
Old 03-24-2007, 10:47 AM   #23
Mmm, that's annoying.
Old 03-24-2007, 07:38 PM   #24
Thanks red91sit. It didn't end up taking THAT much time, and it was spread over a few weeks, so I'm sure you can squeeze in some mod time. :-)
zpiloto and Gary, I'll have to experiment with grille blocks. kps, constant fan running would be a good thing to avoid, huh? :-) I'll be watching out for that.
MetroMPG, I was surprised that the undertray made a difference in the noise level. I'm glad that you confirmed that others have noticed the same. It would actually be easy to add more sound deadening to it. I hope that you get good results with your air dam experiments.
CarloSW2, I'm glad that it was the right level of info for you. Once I got it assembled, I looked at all the wingnuts and thought "what was I thinking?" But it really did make it all go together easier, which is pretty valuable when you're lying on your back under a car.
Old 03-24-2007, 10:20 PM   #25
Hockey4mnhs's Avatar
looks real clean keep up the good work
Old 03-25-2007, 07:01 AM   #26
psyshack's Avatar
My Civic hasn't had over heating issues at all with it engine belly pan. Only thing I can tell it does for me is help to keep the engine compartment cleaner. I cant tell its done a thing for mpg.
09 HCHII, w/Navi
07 Mazda3 S Touring, 5MT
Mild Hypermiler or Mad Man?
Old 04-09-2007, 10:37 AM   #27
Send a message via AIM to eivad1 Send a message via Yahoo to eivad1
is it the lower u go on the air dam the better and more force on the front end, is there a wing for the 87 crxs on top of the hatch
eivad1 is offline   Reply With Quote
Old 04-10-2007, 11:57 AM   #28
Not neccesarily, you go too low, and You increase frontal area causing more aerodynamic drag.
Old 04-11-2007, 12:50 AM   #29
i tried putting tape on the front end of my crx and with-in a 5 miles period the temperature went up, i had to take off the tape, i do tho havea small 2 inch gap that gets to my radiator eand gets air, but was wondering if i could just make some holes in the front nose panel and re tap up the lower part
Old 04-15-2007, 04:03 AM   #30
brucepick's Avatar
Bill in Houston,
I think you did a great job.
I drive an "89 Volvo with OEM air dam that was standard on those cars but I hope to add an extension downward based on what you showed.
Going off-topic - - -
I put in a grill block this past Friday. Tested a full block the day before, looked like a gain of 1.75% with full block in about 35-40 deg. F temps.
For grill block,
I wanted to leave small openings spread out over grill area rather than one single hole. I used lengths of dark gray foam pipe insulation stuffed between the grill slats. I thought it would not show but it's very visible. Insulation is 3/8" thick; squeeze flat and stuff into slot space. Ended up looking like a decent home-brew job. Don't know yet if I'll need to remove it in hot weather. Probably.
Strange fuel-up calculations with odometer. Honva Fuelly Web Support and Community News 3 04-27-2012 05:30 AM
Why doesnt my car show up under 'browse vehicles'? frederic73 Fuelly Web Support and Community News 4 06-17-2011 04:00 AM
Gas Log? GasSavers_Kraig General Discussion (Off-Topic) 3 08-16-2006 02:21 AM
Looking for Insight wheel numbers GasSavers_Ryland General Maintenance and Repair 3 07-08-2006 11:02 PM
Car wrecked. Compaq888 General Discussion (Off-Topic) 80 06-15-2006 12:23 AM
