Adjustable Temp Control Switch - Fuelly Forums
Old 03-23-2007, 04:37 PM   #1
holypaulie's Avatar
Question Adjustable Temp Control Switch
Could that device be useful, to prevent frequent turning on of radiator fans ?
For an instance grill block or hotter thermostat (195 degree).http://cgi.ebay.com/ebaymotors/ZFSWA...QQcmdZViewItem
Old 03-23-2007, 06:33 PM   #2
Well, I think it could, particularly if you used it with a grill block. It sounds like you should be able to let your temperature go a little higher, before the fan come's on, but it would be something you'd have to monitor pretty closely, initially, to make sure you set it up properly.
I think their is a thread about 1-2 months back which talks about a similar device, but the device operates off of the temperature sensor on the block of the engine, instead of off of the radiator. I'd take a look at that, instead, largely because it's the engine temperature which is an issue, not the radiator temperature. I've had several circumstances where a thermostat wouldn't open and the engine would get hot, long before the radiator, because the thermostat wasn't allowing the cooleant to flow correctly.
Language support in the notes field? shedoh Fuelly Web Support and Community News 2 08-28-2012 03:41 PM
Criteria for getting and staying on the overall histogram Codyroo Fuelly Web Support and Community News 1 07-06-2012 05:58 AM
Location filter? BDC Fuelly Web Support and Community News 11 09-05-2009 02:16 AM
Average fuel mileage line in the history graph? BDC Fuelly Web Support and Community News 1 05-06-2009 01:07 AM
New to Site FormulaTwo Introduce Yourself - New member Welcome 15 09-20-2006 08:17 AM
