Add-on sixth gear - Page 2 - Fuelly Forums
Old 04-23-2007, 03:33 PM   #11
omgwtfbyobbq's Avatar
Originally Posted by jdham137 View Post
Yeah, I guess it is an overdrive unit vice a 6th gear. What kind of 4wd parts are you talking about omgwtfbyobbq? I have no idea what a gear splitter is.
Gear splitter! It bolts on to the back of the transmission and can act as an overdrive for each gear, with a .78:1 ratio iirc. I was thinking that maybe a 4wd transfer case could bolt up, but that's probably way to much work. Some kind of planetary gear splitter would likely work w/ fabrication, but, you may be able to bolt up a V6 transmission or use the gear ratios if they have taller versions.
Old 04-26-2007, 07:25 PM   #12
kwtorbe's Avatar
I know that Gear Vendors make sweet overdrive units for mopars...
kwtorbe is offline   Reply With Quote
Old 04-27-2007, 07:46 PM   #13
OMG,
Yeah, a xfer case would be too complicated. My truck is just a plain vanilla rwd type. I'll check out the Gear Vendors to see if they have anything. But I'm not getting my hopes up.
jdham137 is offline   Reply With Quote
Total Spend for last year udtrev Fuelly Web Support and Community News 4 01-12-2010 06:10 PM
Suggestion: Other ideas for comparing cars' data jjmatt33 Fuelly Web Support and Community News 6 08-08-2008 02:38 PM
1988 Honda Acty Attack all wheel drive iburnh2o For Sale 12 06-01-2008 05:30 PM
Happy Holidays everyone! Matt Timion General Discussion (Off-Topic) 10 12-29-2005 12:07 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 05:53 PM
