Acetone - Page 9 - Fuelly Forums
Old 05-22-2007, 08:26 PM   #81
GasSavers_Red's Avatar
Well ran a tankful, MPG difference came out to be 0.4ish MPG. Its no miracle juice, but it seemed to have helped a little. Observations so far are
Starting up after sitting overnight - no more pig rich smell in exhaust
Quieter at cruise and at idle, yet idle speed has no change
Improved throttle response, before it would bog then go, now it just goes
What I thought was a sticky lifter noise seems to have quieted, could have been a dirty injector.
On a certain stretch of freeway quarter throttle would barely hold me at 65, now it inches up to 67ish
If I floor it hard then let off the gas and drop to neutral it will rev up to 1250rpm. Then tach and spedo match needle speed as I slow down
Old 05-23-2007, 03:17 AM   #82
whoaw kitcar you never get to 4% acetone more like 0.3125% = 4oz to 10 gallons
Red - sounds like you have a throttle idle controlled by ecu that needs adjusting
Old 05-23-2007, 11:18 AM   #83
zpiloto's Avatar
Curious those that have had success with acetone could you give the % increase in FE. It seems like every one get 2-3 mpg irrelevant to what the base MPG's was.
Old 05-23-2007, 11:21 AM   #84
Figured as much, just recently cleaned it too......
Old 05-23-2007, 01:06 PM   #85
Mine looks like a 2% increase
Old 05-23-2007, 01:57 PM   #86
milesgallon.com's Avatar
Have anyone tried acetone in diesel?
Simon
Handy gas mileage and automotive calculators at MilesGallon.com lets you find out the real mpg of your vehicle, calculate the fuel consumption and cost for a trip and how about a tool that gives you the total cost per mile for a specifice vehicle over its lifetime.
milesgallon.com is offline   Reply With Quote
Old 05-23-2007, 03:49 PM   #87
Simon
I did give it a try last fall and I got improvement of around 8% at regular speed. But this spring I gave it a second test at low speed (hypermiling or HE) and I saw no improvement. I drive a small Smart cdi 800 cc dsl. See this thread :
http://www.gassavers.org/showthread.php?t=3315
GasSavers_Antoine is offline   Reply With Quote
Old 06-18-2007, 06:17 PM   #88
It just intrigues me how the results can be so different.
Agreed. The user reports for acetone vary from one extreme to the other.
I'm not expecting 35%, but a little octane boost would be worth the price.
broodlinger is offline   Reply With Quote
Old 04-27-2008, 01:41 PM   #89
Originally Posted by tomauto View Post
I wish it were just that easy...IF it was, than it would be in the gas already...
This same subject is what brought me here...but alas, it cannot ever be better than driving techniques.
HOGWASH- Why would the Big Oil Companies want us to get BETTER mileage? Their only objective is to make as much MONEY as they can!
LarryClapp is offline   Reply With Quote
Old 04-28-2008, 10:24 AM   #90
I have a '99 Camry, 2.2L engine. Tried Acetone in 5 or so tanks, with no measurable results.
request: add 3&6 month simple moving averages to the graphs. dudleydog Fuelly Web Support and Community News 2 08-19-2010 02:53 AM
Sort by MPG billcharlton Fuelly Web Support and Community News 2 09-18-2008 05:00 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 02:18 PM
o2 sensor brand durability? n0rt0npr0 Transmissions and Running Gear 13 05-05-2006 02:54 PM
