Originally Posted by SVOboy
I'm not an engineer either, but I think his writings are very far off the mark. If you read through them carefully you will not things that are blatantly not true and/or completely misleading.
It's far from an engineering report :P Claims are qualitative, many without a reason. Why would acetone work with some brands of fuels and not others? This makes me think that your problem isn't that you're not using acetone... It's that you're using a poorly maintained fuel station
Big Oil and the American Car Manufacturers and others do NOT want you to know.
An engineering report would never say anything like that - it destroys your credibility telling everyone you're no longer an objective observer (that's not engineering - that's scientific method). Again, I stand by this. If a single oil company could claim "Our gas may give you 35% more FE reliably" - imagine how quickly their customer base will grow.
This reverse test method will be repeated in the spring with new oil and some other additives in the acetone that I am working on.
So, what this person just said is that they are posting their results BEFORE completion of their testing.
A number of things must be done and these are outlined in other SmartGas articles. The right spark plugs and wires. The right oil. The right thermostat. The right oil filter, etc. Find the best gasoline station in your area. THEN we add a little acetone to the fuel. Or these items may be done concurrently. You will not get good mileage by putting good acetone in bad gas. At least we never have. So that is the methodology we regularly use.
No mention of driving technique.
The pattern seems to be that engineers and researchers are nearly all in favor of acetone while mechanics are split or afraid to try for reasons based on myths.
Obviously, this person hasn't searched through academia - said engineering and researchers' reports
Look at what happened in Brazil. Millions of engines and fuel systems were ruined in that country by alcohol.
Utterly False. Perhaps if they were using methanol - maybe. but they're not and it took them over 20 years to do the switch. But there's no hype in their media about mass engine damage - nor is there any documentation that mass engine damage has occurred. Respect for that article = 0. That person is playing off ignorance now - why didn't s/he say ethanol instead of alcohol. Because yes, there are alcohols that are hazardous to AL. Hell, ethanol is hazardous to fiberglass (so don't be putting it in fiberglass fuel tanks - you boaters :P).
Well how do we know areo mods work?
A-B-A testing - literature in scientific journals - repeatability of results.
Here is a big question... Why are the results not repeatable across all engines (lets even narrow it down to fuel injected). I ask this because part of verification of a result is the repeatability of a result by others in the community. If someone else, following your method, can't repeat it - it's not a result.
When that happens, you're asked to review your results and search for sources of error or external factors that could have influenced your measurements. The key is:
A measurement is not a result (yet).
Please don't get me wrong -
I am willing to test this. But, we all must agree on a viable way to test. Those that claim it works must agree to the testing conditions. And then it must be a long term test using multiple makes/models in different climates (no worries, the statistics of the data will show how temperature effects it).
Again, I'm bashing on the article and the claims it's making without support.
Then, we need to figure out why it works. Honestly, I'm not satisfied with the atomization explanation and I've found not academic/scientific journal that supports that claim. Hell, one web site claimed that it was the increase in octane and higher octane means cleaner burn
I'll even go as far as going surface tension testing (which I have done in the past and I can easily repeat - it's not hard at all).
But to be honest, I'm not so sure a long term test would do any good.... I suspect that it's just going to be lost through the evap system
