Originally Posted by SVOboy
Yes, this test, via the
Throttle Position During Acceleration and its effect on FE thread, is what made me want to try this myself. In my case, though, I wanted to try it without involving any hypermiling techniques.
Originally Posted by Bill in Houston
Mmm-hmm. I think that this is the key. Accelerating as quickly as you can w/o making the ECU put you in open-loop or in a richened state.
I suspect you are right; the car does go open loop under full throttle, but acceleration (by 'feel', anyway) does not change very much between heavy and full throttle. Given that, and that I expected from others' tests that rapid acceleration to be more efficient, I decided to use WOT to (presumably) put rapid acceleration in a worse light, i.e. to see whether it's more efficient even if the driver is not careful with the throttle.
I think the next test I'd like to do is between WOT and rapid closed-loop acceleration, provided I can manage the latter reasonably reliably, e.g. with a mechanical stop under the accelerator.
