A question about turbocharger - Fuelly Forums
Old 08-25-2009, 03:32 AM   #1
Send a message via MSN to ZHangYang
Im doing a research recently, need to get the turbine spinning speed at different working conditions. Yet, lacking of equipments, does anybody know how to get the spinning speed by Mathematics method?
Thanks a lot!
[SIGPIC][/SIGPIC][/SIGPIC]ONE FOR ALL
ALL FOR ONE
ZHangYang is offline   Reply With Quote
Old 08-25-2009, 05:08 AM   #2
Site Team
Thanks a lot!
For a free-flowing application you would do a volumetric calculation based on the volume of the exhaust turbine and the volume of exhaust gas (combined with a few other factors like pressure drop). For a real-world application, you would then have to subtract the resistance from the compressor and friction...
-BC
Old 08-25-2009, 05:41 AM   #3
-BC
if i get the pressure and the temperature of the exhaust gas, and the parameter after it passing through the turbine, is it enough? Is there any formulas I can use?
ALL FOR ONE
Old 08-25-2009, 05:43 AM   #4
For a lot of data and calculations as it applies to vehicle turbochargers, look on a torrent search engine for "Maximum Boost" by Corky Bell.
Old 08-25-2009, 06:50 PM   #5
It seems a complicated question. I decide to check the information in the labrary first. Thank you for your help.
ALL FOR ONE
Old 08-26-2009, 01:48 AM   #6
Site Team
Definitely not a simple calculation, and I'm not sure you'll find a simple formula. You definitely need a lot more information than just temperature and pressure, you have to know the geometry of the vanes and have a complete 3D model of the entire turbine system (as well as some information about the exhaust system to which it is attached).
Why are you looking to determine turbine speeds? Maybe there is another way to skin the cat...
-Bob C.
Old 08-26-2009, 07:11 AM   #7
kamesama980's Avatar
ask the manufacturer. They usually have volumes of info they can look up.
-Russell
Old 08-26-2009, 09:46 AM   #8
GasSavers_bobski's Avatar
You should be able to find flow maps for most turbochargers online.
Here's an example:
Old 08-26-2009, 09:34 PM   #9
Now I realize that it is not a simple question. Maybe I should deal with it based on a computer software. But the direct way to solve the problem is to measure the turbocharger rotational speed by equipment, right?
ALL FOR ONE
Old 08-27-2009, 03:58 AM   #10
Site Team
Again, not so easy - since many turbos spin at 30,000 to 60,000 RPM (and I've heard of some at 100k+ RPM), attaching equipment will most likely create additional drag (affecting your reading), and/or create a balance issue with the spinning turbine (which would cause it to self-destruct in short order). Besides, a tach to read 60,000 RPM is pretty highly specialized.
Are you trying to design a turbocharger?
-BC
Hi from Indiana, USA spacepilot Introduce Yourself - New member Welcome 1 03-07-2008 08:53 AM
'04 SVT Focus jcp123 For Sale 0 01-06-2008 03:16 PM
Assembled EFIE GasSavers_andyj For Sale 0 11-24-2007 05:49 PM
GM: Petrol is Dead Silveredwings Automotive News, Articles and Products 6 06-13-2007 12:06 AM
Arggg.... Hooray For Proprietary Fluids! trebuchet03 General Discussion (Off-Topic) 2 05-08-2007 11:03 AM
