A/F gauge with EFIE? - Fuelly Forums
Old 06-12-2010, 10:27 PM   #1
I was wondering if anyone here has used an EFIE (if so which kind) and i was wondering wheteher or not it is necassary to use an A/F ratio gauge with it? Will a digital multi meter work just for the voltage? which would you suggest?
PowerHaus930 is offline   Reply With Quote
Old 06-13-2010, 05:04 AM   #2
GasSavers_Erik's Avatar
My experience with using a digital voltage meter to monitor oxygen sensor output is that the reading jumps around a lot. You can tell if you are running lean, but the numbers are always jumping around.
Old 06-13-2010, 09:29 AM   #3
I get the same result monitoring my O2 sensor output with my Scangauge. The numbers jump around a lot. The only practical application I have found for watching the output is that its easy to tell if the engine is in DFCO, because that's the only time the sensor output = 0.
Publishing Fill-up Stats from Mobile Site? smknipe Fuelly Web Support and Community News 2 06-22-2011 06:27 AM
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 04:48 AM
Torque Converter slippage + kickdown cable brucepick Transmissions and Running Gear 5 07-23-2007 04:19 PM
GS and YouTube SVOboy General Fuel Topics 2 01-28-2007 11:08 AM
