95metro about to conduct ambitious (blind & controlled) acetone test - cancelled - Page 2 - Fuelly Forums
Old 11-13-2006, 08:19 AM   #11
Originally Posted by JanGeo
You guys need to setup a 1 gallon jug for a fuel tank and run that inside the car with a valve to switch on the gas tank again. The issue is of course the fuel pump DUH!! which is in the tank so a pressurized tank..
Mercy! A separate jug of gasoline (with a switch) in the car with you? A calibrated jug? Please, please don't hit anything! Or... have some clown hit you! ARGH! Fireball city! Will your glass melt? You betcha'! Will your ashes blow in the wind? You betcha'! ARGH! -Ted Hart (from a distance)
Old 11-13-2006, 11:29 AM   #12
Augh come on now Ted - live a little!! Back in my Rambler days a 1 gallon glass jug on the front seat worked great - you could actually see the gas going down as you drove. I figured out then that a stop cost about a cup of gas to get going again. This was back in the early 70's when there were no air bags in cars. They used to show the gas economy tests on TV commercials with the clear jug on the hood or was it in the car? This is going back before you young kids.
Just because a cup of gasoline has the explosive force of a stick of TNT is no reason to Fear it ???
Hey I even wear my cell phone on my left hip right next to my left hand holding the gas nozzle when I fill up my car. RING BOOM!! LOL.
Old 11-13-2006, 11:40 AM   #13
Originally Posted by MetroMPG
Mark cancelled the test. Running the car out of gas proved problematic, and inconsistent:
Too bad, but still gets an "A" for ambition.
GOD I would have told you not to run out of fuel because the first thing that happens when you get low is it starts to suck air from the tank and that makes the engine run really rough. Then the fuel spurts through the fuel lines and can blast junk in the lines right through the fuel filter element. Then the fuel pump is lubricated and cooled by the fuel going through it and in the case of the VW Rabbit the brushes of the fuel pump motor were supposed to be in fuel although I have a hard time believing that.
Old 11-21-2006, 10:06 AM   #14
The danger of running the gas tank dry...
I learned something (the hard way!) about in-tank electric fuel pumps...the liquid gasoline acts as a coolant for the pump! No gas (or, low gas repeatedly) will allow the pump to overheat- burning the windings out (they're just fine copper wires) on the field windings! I (now) never allow the gas gauge...sticky / inaccurate... get below the 1/4 marking! It beats walking!
Old 11-21-2006, 10:16 AM   #15
How many rings? LOL
We "young kids" used to do MPG checks in our '77 Gremlin (A Rambler?LOL) with a calibrated glass cylinder ... actually a large burette ... hanging from the right-side visor mount. Did you notice the huge volume of gas it took to idle?
Napalm is / was? made from mixing gasoline and flake laundry soap ("Kids!" Don't try this at home!). Did you ever slide across a car seat and touch the door handle? Zap! Better than a cell 'phone! LOL
Oh! "Young kids" didn't fight in SEA! Wanna see my medal??? -Ted Hart
