94 Honda Civic Lx DIY MPG gauge questions - Fuelly Forums
Old 11-04-2009, 02:07 PM   #1
I have been interested in making/installing a DIY miles per gallon gauge for some time. Recently I have become familiar with microcontrollers and would like to start on this project. I have been reading many of the threads on Gassavers.org and think I have a decent grasp on how to do this, but I just have a few questions. First I am not sure if the 94 Civic Lx is fuel injected. Also I was not sure how to read the VSS and fuel consumption from the OBD1 pin. I am not sure how to handle the signals and would greatly appreciate any information. Thanks in advance.
HondaCivic94 is offline   Reply With Quote
Old 11-05-2009, 09:55 AM   #2
imzjustplayin's Avatar
look at the mpguino......
Old 03-22-2010, 04:35 AM   #3
Alanmark's Avatar
Q. Just wanted to say thanks for all the helpful hints you give. I have a 1994 Honda Civic LX, 1.5 liter 4 cylinder and automatic transmission. Odometer reads 155,000. Lately the temperature gauge is fluctuating a lot. I noticed it when I am on the highway. When there is heavy traffic and I am not moving much it gets hot.
Honda Civic Temperature Fluctuates
When traffic loosens and I go it cools off. I don't have a leak and I changed my water pump in December 2003. Any ideas you can give would be greatly appreciated. I was thinking it was the thermostat, But you would know better.
Thanks,
Carlos
A. This is a classic symptom of an inoperative electric cooling fan. When you are moving, air comes in and flows through the radiator, cooling it down. When you are stopped, no air flows through the radiator and thus no cooling takes place.
To confirm this start up the car and let it idle with a thermometer in the radiator. The fan should come on between 190? to 200?F. It should shut off at 182? to 188?F.
If it doesn't, you probably have a bad Cooling Fan Motor Switch or relay. It may be possible the fan motor itself is bad. If you run a fused, 15 amp, jumper wire to the blue wire of the fan motor connector, the fan should run. if it doesn't leave the wire hooked up and ground the black/wire.
Alanmark
Alanmark is offline   Reply With Quote
SMS Problem kernk Fuelly Web Support and Community News 2 02-27-2011 10:36 PM
new link for Mobile after submit Pontiac Fuelly Web Support and Community News 1 02-07-2009 05:48 AM
Keeping my distance in traffic khurt General Fuel Topics 8 09-07-2008 04:23 AM
Honda TPS Sensors - $15/ea Matt Timion For Sale 7 06-27-2006 12:05 PM
Staying cool without AC kickflipjr General Fuel Topics 23 05-03-2006 11:15 AM
