Not that most of you need a DIY for brakes, but I probably could have used one since this was my first attempt:
The Metro's front brake rotors needed replacement badly. They were rusted right into the friction surface. The long weekend actually gave me time to do it.
Before you jack up your car (I found out the hard way) you have to unstake and remove the axle nuts. Unstaking them is a pain. I basically used a chisel to practically break away the metal. A 25 in. breaker bar and a 1.188 in. socket removes the nut pretty easily (they're torqued to 129 ft lb).
Once the axle nuts are off or at least loosened, loosen lug nut, jack up car, etc.
Not much holding these rotors on. Just calipers, friction with the center hub, the lug nuts, and these two short screws:
Turn the wheels so the caliper bolts can be easily accessed. There are two bolts for the caliper piston and two bolts for the pad bracket. A 14 mm socket/wrench fits perfect.
Hang the caliper from the strut with wire so it's not hanging by the hose. Depress the piston back into the caliper to make room for the new pads.
Remove the pad bracket. The pads are easy to remove and replace.
New pads (top) versus the old pads (bottom). Old pads were not severely worn, but new pads with new rotors is probably better.
These rotors were pretty much rust-welded to the hub. The Hayne's manual suggest a slide-hammer to remove them, but most people haven't even heard of this method it seems...and slide-hammers aren't cheap. I tried a gear-puller and it broke in the process.
I ended up using a harmonic/steering wheel puller. The passenger side rotor popped off okay. The drivers-side just pulled the entire rotor/hub assembly off the axle so I had to use a mallet to beat them apart.
Old rusty rotor versus new shiny rotor:
I'm an anti-seize junkie ever since my front strut fiasco.
New rotor ready to go.
Install the brake pads and caliper. Start vehicle and pump the brakes to get the piston operational - I put the car in 1st gear and let the axles spin. Make certain everything is working correctly. Since this was my first brake job I hadn't realized that the pads a basically in constant contact with the rotor - the piston just supplies/releases pressure.
Once everything is satisfactory install wheels and lower the car. Torque the axle nuts to 129 ft lb and restake them.
Drive the car slowly at first to see how the brakes react. Since my pads weren't severely worn I hardly noticed any difference in the braking.
