Originally Posted by MakDiesel
'85 CRX Si: '85 Si tranny w/ HF 5th gear = ~2750RPM @ 60mph
Makdiesel, could you tell me- 1.) where did you get your HF 5th gear? Junkyard? 2.) That might be a better start for me, but I am curious as to why your engine (12valve d15 just like mine) turns faster than mine at 60mph when you even have the HF 5th gear .  3.) Did the HF 5th gear swap give you much mpg improvement?
1.) I got the HF gear from a fellow RPR member for I believe $30 (good condition).
2.) My engine turns faster because I have the stock Si transmission from gears 1-4, then add the HF 5th, while I believe you have a stock DX tranny. The only true difference between the Si and DX transmissions for a 1st gen CRX is the final drive ratio, determined by the differential. DX's have a taller FD ratio, knocking each gear down several hundred RPM's, despite the fact tha actual individual gear ratios are the same as the Si. The HF tranny has both a taller FD ratio AND individual gears to give it the long legs it has.
3.) The swap actually wasn't as drastic as I had hoped (I didn't do the math beforehand) and so I later picked up a complete HF tranny to one day swap in to cure this high RPM song bird since I drive 80% highway anyway. BTW, if you go w/ the HF 5th gear, only the fifth gear housing has to come off, not the entire tranny. Just jack up the right side and loosen the 5-6 ten-mm cover bolts to access the 5th gear. Also, keep your assembly in the right order! A HELMS manual also helps, which is also provided on RedPepperRacing.com -- Visit there, ask questions, look around, you'll find plenty of answers. Mak
'85 CRX Si Original EW3 @ 254k...suck it Detroit
'89 CRX HF-Z1 ~ When haste is needed
'97 Civic DX Hatch ~ Formerly 600hp, now 0hp, soon 115hp.
