X gauge question - Fuelly Forums
Old 01-08-2009, 01:11 PM   #1
X gauge question
Does anyone know whether there is a way to set up a gauge for a/f ratio?
Hipermiler
#47 on my way to #1
Old 01-08-2009, 02:06 PM   #2
Would the O2 sensor XGauges give you what you want? I don't know what format it's presented in.
If you find it, please post it in my XGauge code collection thread:
http://www.gassavers.org/showthread.php?t=10087
Old 01-08-2009, 08:24 PM   #3
I don't think there is an xgauge code for that. In a round about way the O2 readings will give you what you want.
Old 01-09-2009, 02:22 AM   #4
This question sent me digging yesterday. I found that there's a GM VPW PID for AFR (so hopefully I'll be able to create an XGauge code), but couldn't find one for Ford PWM.
Old 01-09-2009, 06:42 AM   #5
Maybe it may be part of a specific MFR's OBD data, but I don't think A/F ratio is part of the standard OBDII data that can be read from the port. By looking at the O2 sensor readings, and getting a feel for the regular range of values you get on your vehicle you can tell if you are lean or rich.
Old 01-10-2009, 09:27 AM   #6
Thanks for the replies.
theholycow if you come up with anything just post it. I'll be watching.
Hipermiler
#47 on my way to #1
Old 01-10-2009, 01:30 PM   #7
So far, all I've come up with is one for GM (which should interest Jay). In fact, it was right in the XGauge PDF on the ScanGauge website, along with transmission fluid temp and some other useful GM XGauges. I used it and found that mine stays steady unless I run WOT for more than a few seconds; then it can get as rich as 12:1.
Old 01-10-2009, 06:49 PM   #8
I'll have to look that up, but I was right, its not standard OBDII data, its mfr specific. I do have a gauge setup for tranny temp. I was watching that closely when I was suspecting transmission failure a while back.
Old 01-12-2009, 03:50 AM   #9
Nope, it's OBDII standard. http://en.wikipedia.org/wiki/Table_of_OBD-II_Codes
For my 2008 Elantra the lambda equivalence ratio is:
TXD:07E00124
RXF:044145240000
RXD:2810
MTH:006480120000
Under 1 is rich, over 1 is lean.
Or the following to display it as the AFR.
MTH:05BE80120000
tasdrouille is offline   Reply With Quote
Old 01-10-2009, 02:26 PM   #10
GasSavers_BEEF's Avatar
I was going to add that I did it on my cav but it isn't a ford. mine runs 14.7 until I really get into it at which time it hits 12.6.
I wonder if you can compare other codes that are ford and chevy codes to see the difference and maybe apply those differences to the a/f ratio code. maybe it is just a few digits difference. the worst it could do is give you a bogus reading if you don't get it right. it won't screw anything up as it only reads the codes, it doesn't modify them.
I would look at it myself but I have found myself busier than usual here lately.
just an idea
Publishing Fill-up Stats from Mobile Site? smknipe Fuelly Web Support and Community News 2 06-22-2011 05:27 AM
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 03:48 AM
New To H2 For Cars ALTERNA General Fuel Topics 2 07-14-2008 06:29 AM
ccv line cugir321 General Maintenance and Repair 0 06-05-2008 06:55 PM
GS and YouTube SVOboy General Fuel Topics 2 01-28-2007 10:08 AM
