X gauge question - Page 2 - Fuelly Forums
Old 01-11-2009, 04:35 AM   #11
I was under the impression that A/F ratio, as displayed using the XGauge code I used, is reported directly by the computer (hence why a manufacturer-specific code is required).
Old 01-11-2009, 04:11 PM   #12
I posted this question on a couple of other forums and have come up with the following answer. I haven't had a chance to program it into my SG II yet so I'm not sure whether it works or not. I appreciate everyones input and if you come up with anything else please post it.
TDX: 616AF10114
RXF: 044145140000
RXD: 2808
MTH: FFFD00020640
http://www.cleanmpg.com/forums/showt...341#post179341
Hopefully this will help other out as well as me.
Hipermiler
#47 on my way to #1
Old 01-11-2009, 07:58 PM   #13
Ford Man, is that the GM code, or is it a Ford code?
Old 01-12-2009, 04:50 AM   #14
Originally Posted by Jay2TheRescue View Post
I'll have to look that up, but I was right, its not standard OBDII data, its mfr specific. I do have a gauge setup for tranny temp. I was watching that closely when I was suspecting transmission failure a while back.
Nope, it's OBDII standard. http://en.wikipedia.org/wiki/Table_of_OBD-II_Codes
For my 2008 Elantra the lambda equivalence ratio is:
TXD:07E00124
RXF:044145240000
RXD:2810
MTH:006480120000
Under 1 is rich, over 1 is lean.
Or the following to display it as the AFR.
MTH:05BE80120000
tasdrouille is offline   Reply With Quote
Old 01-13-2009, 06:26 PM   #15
After re reading the link that I had posted in my last post I still understand it to be for Ford. The original person has posted since then and given a different configuration for the math that is supposed to eliminate some of the abnormal readings that he had mentioned in the previous post. You probably should read the post yourself. I've been busy for the past couple of days and still haven't had the chance to program it into the SGII.
Hipermiler
#47 on my way to #1
Old 01-14-2009, 09:59 AM   #16
I've looked at the Xgauge PDF, I think I'm going to try the AFR code in my truck. I'd be curious to see if it reads zero in DFCO, as the SG doesn't properly detect DFCO in my truck.
Publishing Fill-up Stats from Mobile Site? smknipe Fuelly Web Support and Community News 2 06-22-2011 06:27 AM
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 04:48 AM
New To H2 For Cars ALTERNA General Fuel Topics 2 07-14-2008 07:29 AM
ccv line cugir321 General Maintenance and Repair 0 06-05-2008 07:55 PM
GS and YouTube SVOboy General Fuel Topics 2 01-28-2007 11:08 AM
