Would a VX engine d15z fit into a 94+ integra? - Fuelly Forums
Old 06-29-2008, 08:30 PM   #6
d15z1 94 teg
I just completed this swap in my gs-R dc2. You need a p07-A00 ecu, vx motor, with wiring harness and 5 wire o2, extra ecu pins and wire, egr control solenoid. Everything will go together real easy. except for running a couple of wires from the ecu to the engine harness and 02 wires, and a wire from the ecu to the egr control solenoid and then to a sensor ground on the driver side of the car. btw no check engine lights.
(2500lbs. Rear disc, bigger front calipers, abs, sunroof, power steering, leather) vs. (2100lbs. none of that)
I can't tell you how much I'm saving in gas yet just going through my 1st 10gal.
onefastcar is offline   Reply With Quote
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
88 CRX HF tranny swap questions.... UfoTofU General Maintenance and Repair 31 04-09-2007 03:55 AM
