Would a VX engine d15z fit into a 94+ integra? - Fuelly Forums
Old 06-29-2008, 01:53 PM   #1
Hi, I'm new to the website. I'm still young but I'm very interested in fuel economy cars. I was just wondering if I am able to put a d15z into an 94+ INtegra? I would highly appreciated if anyone out there would be able to give me some tips on this. Thank you.
xiongthao is offline   Reply With Quote
Old 06-29-2008, 02:07 PM   #2
A civic vx weight 2100 pounds and a Integra weight 2500 pounds and more, so the idea is not good, i would think...
Old 06-29-2008, 02:17 PM   #3
thats true...but would it be possible to put a d15z into other civic cars for example 92-95 coupes or 96-00 coupes? I heard that it's difficult to do a VX engine/tranny swamp into a non-civic vx model
Old 06-29-2008, 02:28 PM   #4
mrmad's Avatar
It can be done. search D series swap on team-integra.net.
The swap is much easier on the 92-95 civics cause they already have a D series in them and they are OBD1
Old 06-29-2008, 02:50 PM   #5
thanks, i'll give it a try
Old 06-29-2008, 08:30 PM   #6
d15z1 94 teg
I just completed this swap in my gs-R dc2. You need a p07-A00 ecu, vx motor, with wiring harness and 5 wire o2, extra ecu pins and wire, egr control solenoid. Everything will go together real easy. except for running a couple of wires from the ecu to the engine harness and 02 wires, and a wire from the ecu to the egr control solenoid and then to a sensor ground on the driver side of the car. btw no check engine lights.
(2500lbs. Rear disc, bigger front calipers, abs, sunroof, power steering, leather) vs. (2100lbs. none of that)
I can't tell you how much I'm saving in gas yet just going through my 1st 10gal.
onefastcar is offline   Reply With Quote
Old 06-29-2008, 09:23 PM   #7
If you're doing a d15z1 swap you should swap the trans as well, or try to get a CRX HF trans. It won't be as sporty as it was before but your MPG will jump significantly.
opelgt73 is offline   Reply With Quote
Old 06-29-2008, 10:17 PM   #8
crx hf tranny is a cable. try vx or hx these are hydro
Old 06-30-2008, 04:57 AM   #9
A hydro to cable swap can be done and it isnt as complicated as the engine swap.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
88 CRX HF tranny swap questions.... UfoTofU General Maintenance and Repair 31 04-09-2007 03:55 AM
