theclencher -
Yeah, I feel your pain. I was all hot to try putting motorcycle tires on my car- skinny, high pressure, yada yada... but would they improve anything? What things would be made worse? Only testing would reveal that I suppose. I'm not aware of any formulas for predicting this sort of thing.
What it means to me is, a heavier wider-than-stock tire is likely not the way to go. But a skinnier than stock tire may or may not help either. More importantly, it means I shouldn't get my hopes up thinking that 60 psi or 70 psi is going to make a material difference in rolling resistance vs. 50 or 40.
I have to read all those posts in detail, but I think this is something that could lead to the overall idea of a general database in GasSavers for drivetrain/mods that work for members.
For example, I would like to be able to see all of the tires on all of the Saturns in order to be able to make an informed judgement. One stop shopping for tires and other mods, so to speak.
This would (obviously) all be voluntary input.
Maybe what I really want is alot of input entries in the Garage that are not required input, but
available for the GasSaver to input. This could be akin to 2 modes. The "basic Garage" is the variable data that is already seen in the Garage. The same car could also have an "Advanced Garage" input form that has all sorts of gruesome details regarding tires, their PSI, and their perceived benefit/detraction to FE.
Also it means that special lrr tires do come at a cost and certain other characteristics are compromised. Maybe the best thing is to run on nearly bald worn out old tires.
That sounds like skinny F1 tires.
Maybe a used-tire co-op would be in order. The co-op would start with a same make/model set of 4 tires with unequal tread wear. The co-op would "true" them to be the same. Arghhhhh, too much effort. I don't want to even think about going that route. Orrrr, do used tire shops already exist????
My pre-GasSaver brainpan is trained to want to buy "really good safe tires" that are rated for alot of miles. But in the gas-saving world, that's alot of sunken-cost that you are stuck with until the tires reach, what, maybe 1/2 way into their tread life? If the tires are dogs, then you are stuck with them for 40K+ miles.
My Gas-Saver tire formula currently juggles these variables ranked in order of importance :
1 - PSI : Shoot for 50+ in order to be able to experiment safely.
2 - Rolling Resistance : Low as possible but still safe. In LA a super-grip tire is not needed because of all the sunny dry days we have.
3 - Size : At or above OEM spec. A larger tire should not be a wider tire.
4 - Weight : Lower than OEM.
5 - Tread Life : leaning toward low in order to mitigate "dog tire" syndrome.
6 - Price : Leaning toward < $70 per tire.
But maybe this is stating the obvious
Re: skewbe 10 speed tires cutting through snow: that is a truth in the north country, that skinny snow tires will outperform fat ones. The skinny ones "cut" down through to where there is better traction and the fat ones float and slide around on top- one reason why an old VW with it's super-skinny tires can embarrass a fancy-pants 4x4 with big tires.
