Winter tire/steel wheel users - How bad is the MPG hit? - Page 2 - Fuelly Forums
Old 06-04-2008, 08:06 PM   #11
civic lover's Avatar
Originally Posted by BIBI View Post
Cause the salt doesn't damage the alloy wheels, so I don't have to pay the extra money for the other rims.
And yes, winter tires are bad for FE, especially if the temperature is not below freezing point, but where I live (Canada) summer tire in winter is not an option, and the governement will past a law next year to force everyone to put them on in winter, a good thing!
BIBI where do you live? The salt does eventually oxidized alloy wheels. Another thing you want to be aware of is where you put your counter wieghts. If you put them on the outside of the rim the salt will get behind the weight and pit up the rim bad. All you have to do is look at my rims.
civic lover is offline   Reply With Quote
Old 06-05-2008, 06:09 AM   #12
Site Team
I've been doing tires part-time since the late 1980s.
The ideal scenario is to have a set of dedicated rims/tires for each driving season.
Every time I do a winter-summer changeover, I cringe because rebalancing requires that I remove all of the old weights and install new weights, and there is either a sliver of aluminum removed (hammer-on weights) or a bit of a sticky mess left behind (stick-on weights). Either way, the rim is "damaged" a bit and takes one step closer to being a POS.
And despite the "common knowledge" that aluminum rims are lighter, they aren't THAT much lighter to have any sort of real impact on gas mileage IMO, and steel rims are always more repairable. Steel rims can be sanded & spraypainted, impossible with aluminum. And if the rim is dented, 95% of steel rims can be hammered back into shape but I've seen very poor results when aluminum wheels are "straightened" after they hit a pothole.
For my car, it's steel wheels year-round.
With regards to FE. In my case, I only put snow tires on the front. It's impossible to judge whether this affects gas mileage, because there are other variables which also change at the same time- the air is colder, and the gas changes to a winter formula. So my winter gas mileage is always worse than my summer mileage, and it's possible that snow tires are part of that, but I can't really isolate it.
-BC
Not very precise mpg calculation larjerr Fuelly Web Support and Community News 4 08-20-2012 02:03 AM
Is it possible to see basic stats in metric? alexg Fuelly Web Support and Community News 3 01-17-2010 10:44 PM
Keeping my distance in traffic khurt General Fuel Topics 8 09-07-2008 04:23 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-22-2008 12:25 AM
Hello from Scotland greengoddess Introduce Yourself - New member Welcome 6 07-31-2007 08:39 PM
