winter driving - Page 2 - Fuelly Forums
Old 10-19-2006, 11:34 PM   #11
If the windows need scraping I'll start it and do that. But none of this idling for 5-10-20-40 minute B.S.
If it hasnt warmed up while idling for 10 minutes it probably wont heat up all the way anyway.
Old 10-19-2006, 11:43 PM   #12
Originally Posted by kickflipjr
You should alow 10 seconds to warm up in cold weather (I can't remember were I heard that). That allows the fluids to move around a bit.
On warm days that are for example 20C+ a very short warm up is all thats needed , perhaps , start , wait 10 or so seconds and then drive off and drive conservativly for another few minutes.
In winter time when its 5C and less the same method can apply but watch the temp gauge and dont use heavy throttle untill it reaches the normal opperating zone.
I tend to idle a little bit longer than I would recomend because as soon as I leave my driveway I enter quite a fast and busy roadway which may require full throttle applications.
But if a person lives in a typical suburban area with low spead roads around them , even in winter time , start up , wait a few minutes and then proceed with gradually increasing loads on the engine untill fully warm.
This should be the nicest on the engine and be a suitable ballance for FE.
FE isnt everything if you rengine wears out in a 3rd of the time , thats not economy.
Old 10-20-2006, 09:30 AM   #13
Just always be late to where you're going. Then you don't have time to let the car idle for 10 minutes.
w00t, finally above the EPA rating!
jolt-tsp is offline   Reply With Quote
Old 10-20-2006, 09:39 AM   #14
If you have the choice when to take your car trip try and arrange the time when its not going to be raining.
Water on the roads and especially puddles suck FE.
Last time I was out and it was raining hard in the sections of roads that I would normally roll down I had to be in gear with the power on.
So , dont go out if its raining.
If its a work day call your boss and explain your FE hobby and why you can't make it in rite now , Ime sure he will understand.
Old 10-20-2006, 09:58 AM   #15
kickflipjr's Avatar
Well, If you have a garage and a block heater that would be the best scenario.
Get all the snow off you car. No need to be carring around that extra weight
2008 EPA adjusted:
Fuelly API, Remote Update hufman Fuelly Web Support and Community News 6 11-26-2017 11:28 AM
Request: Days Between Fuel-ups artizhay Fuelly Web Support and Community News 5 10-30-2012 04:42 AM
Why Is there No App?! muffetmd Fuelly Web Support and Community News 8 03-11-2012 10:06 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 04:31 PM
