Winter Blend - Fuelly Forums
Old 12-22-2011, 08:58 AM   #1
Winter Blend
My MPG has dropped close to 2 MPG since winter has set in. Winter blend sucks!
bakerf72 is offline   Reply With Quote
Old 12-29-2011, 12:29 PM   #2
I hear that. I don't think it's around in my area yet, but I never look forward to it.
radtastic is offline   Reply With Quote
Old 12-30-2011, 10:01 PM   #3
Cold weather will also drop mpg regardless of the fuel blend since the engine takes longer to warm up
Old 12-30-2011, 10:21 PM   #4
^ True story. The MPG drop I get with my car is really bad. 32mpg avg down to 27-28mpg in the middle of winter.
2013 Mazda 3 GS-SKY 6MT (Current)
2015 Mazda 3 Sport GX 6MT (Lease return)
2013 Mazda 3 Sport SKY-SKY 6AT (Ex's daily driver - totalled)
2007 Toyota Matrix Base 5MT (Sold)
MatrixDom is offline   Reply With Quote
Old 12-31-2011, 01:05 AM   #5
Yep. All my vehicles drop MPG in winter, and even with blends, I would put most of the blame on the cold, not the fuel. Just typical.
DTMAce is offline   Reply With Quote
Old 12-31-2011, 01:08 AM   #6
Although, some of you in warmer states with only a 1-2 mpg drop can probably attribute that to the fuel blend, if the temp stays the same. Those of us in the north however, see anywhere from a 3-8 mpg drop, depending on how we drive our cars in the winter (excessive idling, warming up, etc). So from my perspective, a 2mpg change is nothing. My van changes vary from 2-5mpg depending on driving style (city vs highway) even in summer. So honestly that isn't that bad.
Old 01-10-2012, 10:53 PM   #7
Back before the Bush Administration started the ethanol mandate CA used to switch to a high ethanol blend for summer before they outlawed MTBE. I could tell you the exact tank that I got the first slug of the E10 summer blend because my mileage at the next fill up would drop significantly. Somehow by replacing 10 % of the gasoline with alcohol my mileage would settle down about 20% from 33-35 MPG down to 27-29 MPG. After the outlaw of MTBE in CA the mileage never recovered in the summer or winter. Now I lose about 3% in winter or 1 MPG on average with the year around E10 blend. I live in Southern Cal with very mild winters, normally a dozen or so nights that get down to or slightly below freezing and about the same number of summer days with highs of 100 degrees F.
