Wider rim on existing stock tires, Any FE cons? - Fuelly Forums
Old 08-22-2012, 05:40 PM   #1
Im looking to buy a lighter wheel for my 2012 Yaris, it comes stock with 15" steel rims that are 5.5" in width and Bridgestone Turanzas (P175/65R15 84H) on them. I'm looking at the Konig Zero 15" aluminum rim Z156T04385 that is 6.5" in width. Can I use the Bridgestones on the Konigs even though the rims are 1" wider? If the tire fits on the rim and works properly, are there any FE disadvantages to the wider rim and same tire?
Any info would be appreciated!!
MPGmonger is offline   Reply With Quote
Old 08-23-2012, 05:14 AM   #2
Re: Wider rim on existing stock tires, Any FE cons?
The allowable rim width for a P175/65R15 is 5" to 6", so you would be using a rim that is too wide. That would lead to a rough ride and tire wear issues.
FE? This is more about the particular tire, not the width of the rim.
Capri Racer
Visit my web site: www.BarrysTireTech.com
CapriRacer is offline   Reply With Quote
Old 08-23-2012, 09:15 AM   #3
When your rim is wider than the tire, you always run a higher risk of scraping the wheels on a curb or pothole. I always like a bit of tire sticking out past the wheels myself. In addition, narrower wheels are going to be lighter.
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 02:12 AM
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
math to calculate mpg from injector pulse width EH3 General Fuel Topics 15 05-15-2008 05:45 PM
Performance Underdrive Pulleys? cfg83 General Maintenance and Repair 10 09-08-2007 09:04 PM
Fuel cut-off threshold speeds GasSavers_Rotareneg General Maintenance and Repair 10 08-13-2007 06:27 AM
