Why the Civic VX is a superior highway FE machine - Page 5 - Fuelly Forums
Old 09-02-2007, 01:47 PM   #41
As I understand it, the biggest threat to operating a transmission at low engine RPM and in high gear is if you regularly apply a pile of torque to accelerate.
But I doubt the engines we use are capable of supplying damaging torque in that situation.
I do know a guy who had to replace 5th gear in his 5 liter Mustang though, and the rebuilder blamed it on hard acceleration in 5th.
Old 09-02-2007, 06:53 PM   #42
1993CivicVX's Avatar
I'm pretty certain coasting in 5th gear at 1000rpm is absolutely fine for the car/tranny/clutch/engine etc.... It doesn't lug, it's not a problem. I think if you are not running your VX below 1400RPM you are not tapping the potential of the car. Sure I'm a noob to it, but still, 1400rpm is high for this car. I shift at 1400rpm.
three stripes the charm!
Old 09-04-2007, 08:22 AM   #43
I'd say coast in neutral unless you need to slow down. Being in 5th will slow you down if it is in fuel cut mode (above roughly 1200rpm). If you are at 1000rpm, it should go farther in 5th, but it will be injecting a bit (probably more than idle) of fuel to do so.
thats my guess.
GasSavers_James is offline   Reply With Quote
Old 09-04-2007, 09:53 AM   #44
my car goes faster in 5th gear coasting down my hill than it does in neutral. In neutral it gets up to 42 or 43mph. In 5th it gets up to 45. Strange.
Old 09-04-2007, 10:01 AM   #45
fuel economy forum
vegan recipes
green home improvement
honda gas mileage
Mobile Page for Smartphones GTGallop Fuelly Web Support and Community News 1 02-23-2011 10:34 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 09:10 PM
some more familiar driving, LOL Compaq888 General Discussion (Off-Topic) 20 04-07-2009 01:37 PM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
Civic modified to get 53 mpg. Matt Timion General Fuel Topics 1 09-27-2005 09:57 AM
