Why the Civic VX is a superior highway FE machine - Page 2 - Fuelly Forums
Old 10-29-2006, 06:57 AM   #11
Another interesting quote (p. 23)
Old 10-29-2006, 07:26 AM   #12
basjoos's Avatar
The CX has the exact same gear ratios as the VX and yet it has a fairly low tech, 2-valves per cylinder ICE. My CX has the DX ICE, which has less low end torque than the stock CX ICE. So the availablility in the VX of an ICE with enhanced low-end torque resulting from the use of variable-valve timing isn't a good enough excuse for the transmission's gear ratios used in the VX. These gear ratios could be used with any car that wasn't going to used to tow heavy loads.
aerocivic.com
Old 10-29-2006, 07:35 AM   #13
fuel economy forum
vegan recipes
green home improvement
honda gas mileage
Old 10-29-2006, 09:15 AM   #14
The VX might be the king for FE in cheap cars , but what happens when you need an engine rebuild.
I can do my metro engine completely reconditioned for about $1000 , how much for the Honda. ??
You will probably spend a grand doing the head and cams only.
Old 10-29-2006, 09:43 AM   #15
Apparently the tuner crowd is throwing VX engines to the curb in their zeal for power. Making used working engines free / cheap. Yes, SVOMaster?
Old 10-29-2006, 09:58 AM   #16
krousdb's Avatar
You can find D15Z1's (the VX engine) on ebay for $300-500 and another 250 for shipping. They come from Japan and usually have less than 40k miles. But I'm not too worried about that now. Mine only has 144k miles. I put 275k on my 85 HF and it was still going strong.
Old 10-29-2006, 10:05 AM   #17
In OZ we used to get a lot of these low milage engines form Japan , and most were crap.
They get abused , no services , excessive idling , and thrashed fom cold.
I have seen inside these 40k engines and they look like 100k worth of wear.
I wouldnt wast my money , even for free.
Old 10-29-2006, 10:07 AM   #18
Originally Posted by SVOboy
It's believable. I believe. For the average driver who shifts at average points and cruises at 70-75, huge difference in RPM.
Maybe my swap isn't as extreme as I thought then...
Old 10-29-2006, 01:37 PM   #19
Matt Timion's Avatar
As Krousdb pointed out, you can get a d15z1 from japan for cheap. YOu can get them for $350 from an importer, plus shipping. If you happen to live in Southern California you can get the engine delieved for free.
$350 for a fresh engine with less than 60k miles on it is much better than a rebuild. The rebuild kits for those engines usually cost over $400.
Old 10-29-2006, 04:12 PM   #20
kickflipjr's Avatar
At 55 mph, I saw about 54 mpg. Dan, on the other hand has shown he can keep the VX in lean burn (without drafting) and get 75 mpg at 55 mph. Nuff said.
So, I rarely do highway driving at the moment (I almost never exceed 50-55mph). So a VX is the car for me, right? At what point it the metro better?
2008 EPA adjusted:
Mobile Page for Smartphones GTGallop Fuelly Web Support and Community News 1 02-23-2011 10:34 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 09:10 PM
some more familiar driving, LOL Compaq888 General Discussion (Off-Topic) 20 04-07-2009 01:37 PM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
Civic modified to get 53 mpg. Matt Timion General Fuel Topics 1 09-27-2005 09:57 AM
