Why not to use Seafoam in every tank for FE - Fuelly Forums
Old 04-26-2009, 06:41 PM   #22
|V3|2D
thisisntjared's Avatar
Originally Posted by hi tech hillbilly View Post
isnt seafoam essentially kerosene? i use kero to clean oil sludge out of engine blocks before they go to the machinist. i definately would not be putting that in the oil, would thin it out and lower oil pressure too much and cause un-necessary wear.
if you put it in the crank case you are only supposed to go for a quick drive, then do an oil change.
Full tank of fuel or not? elvyn General Fuel Topics 9 03-24-2010 10:53 PM
Does anyone put their GasSavers sigs on other car forums? (Also, the $15 gallon....) landspeed General Discussion (Off-Topic) 5 05-27-2008 12:10 AM
A reminder about injector cleaning gto78 General Fuel Topics 29 03-07-2008 05:03 AM
6Cyl running on 4 TeamExploder General Fuel Topics 6 11-09-2007 06:00 PM
Just fired up the swamp cooler Matt Timion General Discussion (Off-Topic) 13 08-04-2006 05:43 AM
