Which Truck Has better Fuel Economy - Fuelly Forums
Old 02-09-2012, 12:53 AM   #1
Hi there, i am looking at either a 2011 dodge ram 1500 or a 2008 ford f-350 super duty diesel, i just wanted some input on which truck would cost the least on gas/diesel there are so many variations on sites out there i just wanted to see. Thanks Ahead of Time
Dillon18 is offline   Reply With Quote
Old 02-09-2012, 05:06 AM   #2
Re: Which Truck Has better Fuel Economy
Which engine in the Dodge? The 390-hp 5.7L V8 does not do well on gas. It gets worse mileage than comparable engines from Ford and Chevy. Rear end ratio also makes a big difference. Also, note that diesel is more expensive than gas.
Old 02-09-2012, 04:12 PM   #3
The Dodge is the 5.7L yes, and the Ford is the 6.4L, i know that diesel is more expensive but dosent it go longer.
Old 02-09-2012, 04:27 PM   #4
in a straight comparison, a diesel engine of the same size will usually out-perform a gas engine of the same size when it comes to fuel economy. What you have to remember, though, is that the Ford has a larger engine and the truck probably weighs nearly a ton more. Not the the Dodge is a lightweight, but a 1/2 ton truck versus a one-ton truck... that Ford diesel has a lot of weight to lug around.
I'd say to get the truck that best suits your driving needs. If you're going to be hooked up to a trailer most of the time, definitely go with the Ford. If you're going to be tooling around town with a small load in the bed, get the Dodge.
Old 02-10-2012, 12:33 PM   #5
Thanks very much for your help really appreciate it
Old 02-12-2012, 12:57 PM   #6
That Dodge will average you around 17 mpg without modifications and not acting like a kid behind the wheel. The Ford will average you about 22mpg without mods as long as you aren't towing a battleship. Upgrade the turbo, exhaust and reflash the PCM and you should be able to see 30 or more all day on the highway with the ford. Best case out of the dodge might be 20.
If you don't foresee yourself modifying them, get the one that is easiest to drive around in.
madnessspirit is offline   Reply With Quote
Old 02-18-2012, 09:57 PM   #7
It's not going to matter much, diesels aren't cheaper because they get better fuel economy, it doesn't work out that way.
Diesels require maintenance that is far costlier than a gasoline engine so it all adds out in the end.
Old 02-18-2012, 10:01 PM   #8
Maintenance intervals are much longer on the diesel engines.
Old 02-19-2012, 12:52 PM   #9
I had a powerstoke 6.0 for a long time. Hated it, the mileage sucked. My 2011 gas F150 3.7 V6 gets better mileage.
Old 01-24-2014, 04:41 AM   #10
I just purchased a new 2013 F-150 ecoboost 3.5 twin turbo truck, and have been driving it like an old lady. So far I am not able to get above 14.6 mpg. Can someone give me insight about this? It was a demo and has 6000 miles on it. Will I eventually get better gas mileage, or is there something I can do to improve the mpg? HELP.
ejstrickland is offline   Reply With Quote
fuel-up entry suggestion fugalaya Fuelly Web Support and Community News 3 04-12-2009 09:29 AM
searching? blind monkey General Discussion (Off-Topic) 7 01-09-2009 07:16 PM
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 01:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 02:50 PM
