Which fluid? - Fuelly Forums
Old 07-31-2007, 04:25 PM   #1
Which fluid?
I'm considering changing the fluid in the front diff. of my manual 95 metro since its still the same that came from the factory over 120,000 miles ago. Now, apparently with a manual transmission you can put either normal gear oil in it, or ATF fluid? What's the difference and what do you think I should use? It was quickly explained to me that you can use either or, but ATF fluid is thinner whereas gear oil is thicker? I think mine came from the factory with 75w90, can anyone confirm this?
I have access to acouple different weights of gear oil, regular ATF, and syntetic ATF at the price of cost at my work..
Nic
Old 07-31-2007, 07:59 PM   #2
look in your owners manual or get a haynes manual it will say. use what it says or you might be buying a new tranny.
Old 07-31-2007, 08:18 PM   #3
I cannot confirm your fluid type, but your very BEST bet is to call a Chevy Dealerships service department, and ask them.
-unknown
Old 07-31-2007, 08:24 PM   #4
DracoFelis's Avatar
Why would that be the "best bet"? Wouldn't they tend to follow the normal dealership approach of recommending the "official fluid" for the vehicle, even when some other fluid might work a lot better?
Personally, I think the proper place to ask about car fluids is the "Bob is the oil guy" forums:
http://theoildrop.server101.com/forums/ubbthreads.php
Old 07-31-2007, 08:31 PM   #5
Draco,
Thats the best bet because I percieved the author as not knowing what fluid was originally in his manual tranny. If he does know that, then he should take that knowledge over to BITOG where he can ask further recommendations.
-unknown
Old 07-31-2007, 08:32 PM   #6
skewbe's Avatar
I've been considering atf for my metro, but may go with what the metro experts are using: GM Synchromesh, part # 12346190, 2.5 quarts.
Stay away from the 70/90 paste mentioned in the non-suzuki manual if you want decent mpg and happy shifting.
here a couple discussions about it on teamswift (metro clones):
http://www.teamswift.net/viewtopic.php?t=32690
http://www.teamswift.net/viewtopic.php?t=19392
Standard Disclaimer
Old 08-01-2007, 06:57 PM   #7
thanks all. I dont have a manual and I heard that the information in there regarding weight is incorrect anyways. I'll check those links out skewbe, thanks.
I'd like something thinner to decrease drag but not too thin..
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 01:49 PM
LPG conversion SVOboy General Fuel Topics 4 03-24-2007 10:33 PM
Auto to Manual Reverse Light Question SVOboy General Fuel Topics 9 03-15-2007 10:28 PM
vx 5 wire o2 sensors on eBay!!! budomove For Sale 3 12-19-2006 07:41 AM
