when to shift for my rsx - Fuelly Forums
Old 02-07-2008, 10:56 AM   #1
i want to get the best mpg through using the best shifting method. i have an Acura RSX base auto w/ tiptronic. when should i shift for best MPG?
ponie2kool is offline   Reply With Quote
Old 02-07-2008, 11:44 AM   #2
thecheese429's Avatar
already been discussed
http://www.gassavers.org/showthread....ighlight=shift
-Becoming the Archetype
thecheese429 is offline   Reply With Quote
Old 02-07-2008, 01:27 PM   #3
Originally Posted by thecheese429 View Post
um, no i'm not using a vacuum gauge like that guy is using. read my question carefully before you speak. plus this guy is driving a totally different car than i am. all cars has different gear ratios. especially his generation vehicle year make comparing to mine. his is a v6 and mine is a 4 cylinder
Old 02-07-2008, 02:23 PM   #4
it's simple really. Where is the torque peak in your power curve? if you never exceed the torque peak you aren't wasting revolutions.
Old 02-07-2008, 04:48 PM   #5
i'm a little confused about the torque peak. are you talking about the redline?
Old 02-07-2008, 10:51 PM   #6
your engine makes 160 hp near redline but 141 lb/ft of torque at just 4400 rpm . 4400 RPM is your torque peak. That is where your maximum torque is produced. stay below this RPM and you should get slightly better milage.
Finding this took 2 minutes with google.
Old 02-08-2008, 05:46 AM   #7
Rower4VT's Avatar
Every engine is different. I have a '94 Vigor with a torque peak of 170 at around 4500-5000 rpm (can't remember exactly). I shift prior to 2000rpm almost everytime...usually closer to 1700rpm unless I have to accelerate up a hill...for example, pulling a way from a stop sign and immediately on an uphill. Downhill I'll shift before 1500rpm. It's really whatever your car can handle. You just have to learn how low of an rpm your car can handle in each gear without the herky-jerky or the engine sounding like it's straining. Obviously the lower you shift the slower you'll have to accelerate, so it depends what you're willing to deal with also. I've had a few people give me dirty looks for accerating slower than they'd like me to.
[SIGPIC][/SIGPIC]
E85 ~$3.17/gal.
Rower4VT is offline   Reply With Quote
Old 02-08-2008, 07:11 AM   #8
I dont think that using the Tiptronic transmission will give you better FE than the 5 speed automatic. Also, you have I-vtec technology, so your FE is better. What MPG do you get on highway (and at which speed)?
Old 02-08-2008, 11:16 AM   #9
kamesama980's Avatar
since it's an auto, just let it be one. you won't gain more FE than it can get you without going to a different (type of- IE manual) transmission. manual shift mode autos ftl
-Russell
I can dream can't I? MnFocus Aerodynamics 23 05-19-2008 05:28 AM
Tow trucks, not in China! Spule 4 General Discussion (Off-Topic) 6 12-25-2006 09:51 PM
Going up big hills Hockey4mnhs Hypermiling 7 12-17-2006 09:35 PM
Really interesting read... Compaq888 General Fuel Topics 0 02-07-2006 04:59 AM
What does a coil do? Matt Timion General Maintenance and Repair 5 11-28-2005 08:56 AM
