I have been experimenting a little with different wheels lately. I have tried some combinations of rims, tires, wheel diameters etc. Since joining GasSavers, I have also begun trying out Pulse & Glide.
In my quest for longer glides, I'm starting to wonder if using the heaviest possible wheels would be the most optimal. The wheels would store a lot of energy compared to their weight and as long as I don't use the brakes, it will be a win. When I bought new wheels recently, I opted for super lightweight rims and large diameter tyres to bring down rpm. While these wheels go nice with the general characteristics of this rather sporty car, it may not do much for FE and P&G. Am I thinking in the wrong direction here?
I'm also thinking of lowering the car to at least restore original ground clearance. The big wheels raised the car by 1". I have seen conflicting information on what effect this has on aerodynamics. My (stock) front airdam already covers the belly parts pretty well. Would an aircraft have less drag flying very close to the ground? Intuitively, I would say the drag will increase...
Lowering normally means stiffer springs, which will affect the workload of the shock absorbers. I have never seen this being discussed so I'm bringing this up also...
The shock absorbers suck up a lot of energy depending on road conditions. (Desert rally cars with burning wheels from overheated shocks, spring to mind). I haven't done the math but a car with harder suspension should waste less energy than a soft one. You can literally feel this if you have ever tried a bicycle with shock absorbers.
Anyone seen any work on this ?
BTW. - Here is my latest project.
Honda Prelude - generation 4 (with oversize lightweight wheels)
This car looks like it should have very good aerodynamics. I have never seen any figures though...
