wheel skirts going on right now - Page 4 - Fuelly Forums
Old 11-15-2006, 10:14 AM   #31
Yeah, I like the look of that.
Old 11-15-2006, 12:43 PM   #32
cfg83's Avatar
lovemysan -
Originally Posted by lovemysan
The more I look these pics the more I want to shorten the rear control arms to narrow the track of the car.
That would make a great question or project/answer for the www.saturnfans.com website too!
There is something really nice in the Saturn S-Series look that seems to allow for aerodynamic mods. The nose is very "soft", so to speak, and the lines are clean, so things like your engine grill block go on well.
Old 11-15-2006, 05:21 PM   #33
basjoos's Avatar
Originally Posted by repete86
Ouch. They certainly don't make it easy. That's one of the reasons why I probably will never build a belly pan. The other is because this is Florida, and if I'm going to be blocking the grille, a belly pan will be way too much on the engine due to heat. The heavy rain in the summer won't help either with a nice little bowl shaped compartment on the bottom of the car. I think that even the grille block is going to be pushing it and will only go on when I'm travelling long distance.
If anything, the midstate of SC gets hotter than FL with quite a few days over 100F in the summer, and I have had no problems with overheating while driving around with a grill block and belly pan on my car. True, I have had to open my grill a little more than Dan has had to on his VX to get enough cooling in his cooler location (a 4"x4" opening for me versis a 4"x2" opening for Dan). And if the outside temps remain below 80F, I close off my grill completely. You just have to figure out what your car's actual cooling requirements are and adjust the amount of grill opening to those cooling needs. The grill block and the belly pan have also been very effective at keeping the water from invading the engine compartment on those times where I have accidentally hit a deep puddle of standing water on the road.
aerocivic.com
Old 11-15-2006, 05:42 PM   #34
Repete, i had taken my grill block off cause was just tied on with tape. i found some zip ties and fastened it more securely. i live near the beachs here and went to the mall and back and only time temps got up there was when stopped for a while in traffic or when i hit a few light back to back. as long as i could move temps stayed down where i liked them. this was a full grill block and only openings was the two small ones in front. it's helpfull to have a scanguage to monitor temps cause the temp gauge in dash hardly moved once warmed up.
you might want to try cardboard or somethign you can trim up easily at first to see what you car needs.
Old 11-15-2006, 07:31 PM   #35
lovemysan's Avatar
My problem is I believe that 200f WT is the breakpoint for effeciency. The computer alters fuel and timing when 200f is exceeded. Thats a narrow margin when your running a 190thermostat. Tomorrow I'm going out for an hour to see if it gets hot running loaded on the interstate.
Two other things to consider about my car. First is I generally have 300-600 pounds of load in the car. Plus I have a larger car with a larger engine. It also has to user friendly enough for my wife not to overheat the car.
If I could get good fuel economy at 215f max I would be fine. I have to be careful though.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 11-15-2006, 08:28 PM   #36
The Toecutter's Avatar
cfg83, that was exactly what I had emant!
Old 11-16-2006, 06:26 AM   #37
lovemysan's Avatar
Originally Posted by cfg83
lovemysan -
There are 2 issues when shortening the rear track. The strut towers and tire clearance. I think you could narrow nearly 3 inches on both sides before major mods to anything but the arms and towers.
Well I don't frequent Sfans much. Everytime I post some good numbers up I get these people chiming in making ridiculous clames with no T2T data. Its an excellent diagnostic source though. I will be posting my aero mods. HAHA. Just to create a stir.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-16-2006, 06:54 AM   #38
Be cool to smooth out the wheel well buldge altogether in the rear so it is nice and smooth. Starts taking on the look of the EV1. I always wondered why they keep putting a lip on the wheel wells instead of like the old Jags which had a nice clean cutout.
Old 11-16-2006, 10:44 AM   #39
GasSavers_Jack's Avatar
I always assumed it was to prevent bending and denting. It is harder to bend a piece of angle iron than the same size flat stock. I thought is was there to prevent dents from very minor stuff like shopping carts and doors and stuff.
See my car here:
Old 11-16-2006, 02:23 PM   #40
you need to see what temps you car runs at during different driving situations.
if you car has a 190 thermostat then in summer is must get over 200 with ac running if you use it much.
300-600 lbs?
iphone mobile broken RicksCafe Fuelly Web Support and Community News 2 01-22-2012 07:02 AM
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 01:25 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-22-2008 12:25 AM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 08:40 PM
Dilemma concerning front sway bar on n600 Matt Timion General Maintenance and Repair 3 05-24-2006 10:37 AM
